Jon White Posted March 5, 2007 Share Posted March 5, 2007 Ok........stupid question time! The bonnet on my 95 classic lines up fine on the passenger side, but is too high at the back on the drivers side! I've looked at it and fiddled with the bolts that hold the hinges to the bonnet, but I cant improve things. Is there any adjustment on where the hinges bolt onto the bulkhead? If not how do i adjust this? Thanks Jon Quote Link to comment Share on other sites More sharing options...
pugwash Posted March 5, 2007 Share Posted March 5, 2007 have you tried a liberal dosing of tool number 1? Quote Link to comment Share on other sites More sharing options...
Jon White Posted March 5, 2007 Author Share Posted March 5, 2007 Er........ not yet - this is not my series and the bodywork is still fairly straight...........I'm trying to do this the "proper" way!!! Jon Quote Link to comment Share on other sites More sharing options...
bishbosh Posted March 5, 2007 Share Posted March 5, 2007 Jon, The bonnet hinges normally have a collection of shims between them and the bonnet. (They are basically slotted washers so you don't have to take the bolt right out to get the shim out) It should be a case of simply adjusting the number of shims.... but I am guessing that you haven't got any..... in which case you will need to take the decker panel off which is a pain as the bonnet needs to come off and you will have sprung loaded hinges........ I think once the bodywork is out of the way that the hinges can be adjusted on their mounts. I won't however guarantee it! Quote Link to comment Share on other sites More sharing options...
Jon White Posted March 5, 2007 Author Share Posted March 5, 2007 Thanks Bish. there are definately no shims between the bonnet and hinge. I'll have a fiddle tonight and see. I really wish i looked at it when i took the decker panel off the other day to fix the wipers.........sigh......... Jon Quote Link to comment Share on other sites More sharing options...
Jon White Posted March 5, 2007 Author Share Posted March 5, 2007 Hmmmmmmmm well I've had a fiddle tonight........and got nowhere! There are two bolts that hold the hinges to the bulkhead which are accesable with the bonnet open. However these appear to run in round rather than slooted holes, and are screwed into threaded inserts in the bulkhead. There are definately no shims between the hinges and the bulkhead. I'm at a bit of a loss now. It all appears straigh and un bent, but it just wont line up! Its got to be a good 1/2 - 3/4" high on the drivers side only at the back and it looks stupid! The passenger side lines up perfectly, and the fron edge lines up perfectly aswell. Only other thing I can think of is if the whole bonnet is slightly twisted? Anyone else ever had this problem? Thanks Jon Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted March 6, 2007 Share Posted March 6, 2007 The classic question: Was it like that before you touched it? (You say you've had the decker panel off, and bishbosh says the bonnet has to be removed before the decker panel can be removed.). Quote Link to comment Share on other sites More sharing options...
bishbosh Posted March 6, 2007 Share Posted March 6, 2007 D'oh! Just realised we've ignored the bluddy obvious!!!!! The decker panel to wing connection is also packed out with washers. Try looking at the low side of the decker panel and see if you can shim that up a bit. Sorry for being thick earlier!!! Quote Link to comment Share on other sites More sharing options...
Jon White Posted March 6, 2007 Author Share Posted March 6, 2007 Hmmmmmmmm its never been right since I've had the truck. The bonnet is definately not the origional cos under the blue paint where its flaking in places in a nice shade of epsom green! The decker panel is on right, and looks right. Its the bonnet thats not..........I'll take some piccy s and post them. It'll probably be easier that way. Cheers Jon Quote Link to comment Share on other sites More sharing options...
Jon White Posted March 11, 2007 Author Share Posted March 11, 2007 Sorted!!! Took both hinges off and compared them - drivers side one was bent! A quick adjustment with tool No.1 and it now shuts right! Cheers Jon Quote Link to comment Share on other sites More sharing options...
bishbosh Posted March 12, 2007 Share Posted March 12, 2007 Could there ever be a more apropriate solution for you Jon! Glad it worked out in the end. Quote Link to comment Share on other sites More sharing options...
