Peterla Posted March 24, 2007 Share Posted March 24, 2007 I am looking at installing a EGT, Boost and voltage gauge in my 200 Tdi. Can any one help me with where I can get a console to add to my dash. Some thing that looks like it is suppost to be there would be perfered. Thanks Pete Quote Link to comment Share on other sites More sharing options...
russ3120 Posted March 24, 2007 Share Posted March 24, 2007 I1, going to do something similar, but i am going to construct a box out of ally and shape it to the contours of the dash. couple of self tapping screwws to secure it to the dash. Will post some pics when its done Russ Quote Link to comment Share on other sites More sharing options...
headhunter Posted March 26, 2007 Share Posted March 26, 2007 I am looking at installing a EGT, Boost and voltage gauge in my 200 Tdi.Can any one help me with where I can get a console to add to my dash. Some thing that looks like it is suppost to be there would be perfered. Thanks Pete Kev Baldwin (on here) sells a Defender centre console for 200/300tdi, similar to the TD5, through his company Mudstuff.co.uk. Excellent product and not expensive. John Quote Link to comment Share on other sites More sharing options...
expat69 Posted March 29, 2007 Share Posted March 29, 2007 Kev Baldwin (on here) sells a Defender centre console for 200/300tdi, similar to the TD5, through his company Mudstuff.co.uk. Excellent product and not expensive.John I'm currently fitting one of them in my Disco 300. It fits right over the centre tray. Quote Link to comment Share on other sites More sharing options...
russ3120 Posted March 29, 2007 Share Posted March 29, 2007 I'm currently fitting one of them in my Disco 300. It fits right over the centre tray. you got any pics? Quote Link to comment Share on other sites More sharing options...
tpk241 Posted March 29, 2007 Share Posted March 29, 2007 I'm currently fitting one of them in my Disco 300. It fits right over the centre tray. Any pic's of this Expat ? Can you post some when done ? Cheers TPK Quote Link to comment Share on other sites More sharing options...
expat69 Posted March 29, 2007 Share Posted March 29, 2007 Any pic's of this Expat ?Can you post some when done ? Cheers TPK Doing the pics today and tomorrow, but will be posted after the 6th April (don't ask... ) so far so good in term of install. The base plate is only 6mm wider than the tray. Also I did not want to completely block the vent (radio one). So plate is resting at front of the dash, goes over the tray and 1/2 cover the radio vent installation so far: - removed rubber mat from tray - drilled hole in the tray area (more towards back of tray and big enough) - drilled two 5mm holes in plate and tray to put machine bolts - you need to fit the bolts (5x40) from the inside out and the nuts over the plate (otherwise you cannot refit the radio) - big hands are not very useful... - ran my wires (spread them in the hole and leave some slack... as when you fit the radio back on it will be a close fit) then it's the standard installation of switches, gauges.... I have to say that it looks very neat... Hope it helps Xavier Quote Link to comment Share on other sites More sharing options...
russ3120 Posted April 10, 2007 Share Posted April 10, 2007 Xavier on pics of the new console? Russ Quote Link to comment Share on other sites More sharing options...
expat69 Posted April 10, 2007 Share Posted April 10, 2007 Xavieron pics of the new console? Russ yes... on the mudstuff site: HERE at the bottom Cheers Xavier Quote Link to comment Share on other sites More sharing options...
russ3120 Posted April 10, 2007 Share Posted April 10, 2007 nice work, did it take long? Russ Quote Link to comment Share on other sites More sharing options...
expat69 Posted April 10, 2007 Share Posted April 10, 2007 nice work, did it take long?Russ fitting the plate - about 30min (with time to get the tools out)... wiring... - more - because I'm useless Quote Link to comment Share on other sites More sharing options...
russ3120 Posted April 10, 2007 Share Posted April 10, 2007 fitting the plate - about 30min (with time to get the tools out)...wiring... - more - because I'm useless Ain`t we all, god i hate wires Russ Quote Link to comment Share on other sites More sharing options...
