Paul Posted April 28, 2007 Share Posted April 28, 2007 Paul are yours the narrower type?I've not touched the later wider ones I fitted a while back now Yeah Tony, mine are the earlier narrow type. I suppose the later wide ones might last better, but there's a heap of messing to make them fit my axle so I'll have to live with it. Doesn't explain the way I can trash panhard rod busehes as well though. Quote Link to comment Share on other sites More sharing options...
SteveG Posted April 28, 2007 Share Posted April 28, 2007 I run genuine L/R ones in all arms nowand soon I'll be replacing the rear trailing arm/chassis mounts they are the originals fitted after 140k and lots of offroad work I seem to recall reading somewhere, maybe Simon on D44 forum, the the wolf rear radius arm bushes are worth fitting. Anyone have any experience of this? Tony, you should buy some X-joints from Si then you won't have to worry about the chassis mount bushes Cheers Steve Quote Link to comment Share on other sites More sharing options...
Paul Humphreys Posted April 29, 2007 Share Posted April 29, 2007 Well I will have to get some as well then. Sritpart ones only lasted 3 weeks in my 110 and the ones in now have been in 3 weeks I also need to do the Padhan rod bushes soon as well.Paul Well they have gone again, only 3 weeks again so ordering some tomorrow. Paul Quote Link to comment Share on other sites More sharing options...
GBMUD Posted April 30, 2007 Author Share Posted April 30, 2007 Thanks guys for sharing your experiences. FWIW, I replaced the Poly-bushes with some metal/rubber ones from Bearmach. They seem to last as well as any others - including the genuine LR ones I forked out for a few years ago. When they expire I might give Super Pro a try, after all David has plugged them so hard! - no pun intended. Chris Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted April 30, 2007 Share Posted April 30, 2007 You know me Chris, if it works well and is VFM, plug it! Quote Link to comment Share on other sites More sharing options...
