Airborne Posted May 26, 2007 Share Posted May 26, 2007 Hello I am looking to have my cam belt changed, I am tempted to do it my self after reading through the technical forum. Before I have a go, a couple of questions. First how much would a garage charge to do it? Second does anyone know a good mechanic who can do it near Gravesend Kent? Third is it really as easy to do, as the tech forum suggest? Thanks. Ian Quote Link to comment Share on other sites More sharing options...
western Posted May 26, 2007 Share Posted May 26, 2007 just follow the tech archive thread & it's that easy. have a go & save some pennies. Welcome to LR4x4 too Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted May 26, 2007 Share Posted May 26, 2007 Ian You have a PM Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 27, 2007 Share Posted May 27, 2007 The crankshaft bolt and viscous fan unit might make things difficult if they refuse to come undone, and the three water pump bolts that seize up sometimes. Apart from that it is pretty straight forward. Les. Quote Link to comment Share on other sites More sharing options...
Holyzeus Posted May 27, 2007 Share Posted May 27, 2007 if you decide to let a garage do it PM dred90, hes just used a Landy garage in Canterbury (not far from you?) Quote Link to comment Share on other sites More sharing options...
michael calvert Posted May 28, 2007 Share Posted May 28, 2007 if you decide to let a garage do it PM dred90, hes just used a Landy garage in Canterbury (not far from you?) if you do it yourself make sure you paint mark all the pulleys together and back to the casing, also check the tensioner and all the bits you have are what you need! Quote Link to comment Share on other sites More sharing options...
dred90 Posted May 29, 2007 Share Posted May 29, 2007 if you decide to let a garage do it PM dred90, hes just used a Landy garage in Canterbury (not far from you?) Yep, take it to Landroversolutions in Canterbury, if you're not doing it yourself. I think it was about £40 / hour on the labour side. V. pleased with the work done on my truck, last time i took it there.. 01227 861186 Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted May 31, 2007 Share Posted May 31, 2007 Bring it to us, we charge about 18 quid an hour Quote Link to comment Share on other sites More sharing options...
