Removing Rear Windows
I want to remove the rear slinding windows in the back of my 110 CSW.
Is there a replacement panel available to fit or will i need to fix a piece in and then fill over it and re-spray?
I still want to keep the rear doors the same just take out the ones in the load bed.
A bit like the new 110 Utillity.
By the way i have a very early 110 so it has the series door tops and the series style rear windows, if i cant remove them can i fit some of the later spec slinding windows in their place or will i need to replace the entire side panel?
Any ideas?
Thanks
Trev
Guest diesel_jim
88" hard top side panels are what you want, they're the same length as the rear panel of a 110 apparently.
correct! series 2/3 88" side panels fit right in.
shame as i've just sold a pair for £20!
Ooops !
Thought you meant others options for windows rather than remove completely :lol:
Fuel cap is a Newton Aerofit (I Fink ) part from Think Automotive in isleworth,
non vented lockable and water proof,
connects into a matching ali machined funnel (also from them)
Minor mods to fit into the hole when the old LR Cr*p stuff is removed
Drill and few holes and tad of filling
then this lot joins into the big bore hose, which has a T piece in it I made going to a breather with a roll over valve.
Means I don't need to worry about water in fuel :)
nige
