Bracco Posted May 28, 2007 Share Posted May 28, 2007 Does anyone know what size bolt/thread is needed to measure end float of the front axles? I have a set of shims coming soon and have not been able to find a proper bolt for the threaded end. 110/MY1985. Thanks Quote Link to comment Share on other sites More sharing options...
Bracco Posted May 29, 2007 Author Share Posted May 29, 2007 Does anyone know what size bolt/thread is needed to measure end float of the front axles? I have a set of shims coming soon and have not been able to find a proper bolt for the threaded end. 110/MY1985. Thanks HELP !!! shims should arrive tomorrow.... M10 is too small, M12 is too big, 7/16 UNF stops after one and a quarter turns... don't have a UNC... yet Quote Link to comment Share on other sites More sharing options...
GBMUD Posted May 29, 2007 Share Posted May 29, 2007 The bolts that hold the diff centre bearing caps in place are the correct thread. Perhaps UNC but more likely some novelty thread like Witworth or somesuch. Chris Quote Link to comment Share on other sites More sharing options...
mmgemini Posted May 29, 2007 Share Posted May 29, 2007 The bolts that hold the diff centre bearing caps in place are the correct thread. Perhaps UNC but more likely some novelty thread like Witworth or somesuch.Chris I don't see a Whitworth thread as a novelty. More as an original mike YES !! It is a free country. As long as you do as you are told. Quote Link to comment Share on other sites More sharing options...
steve_a Posted May 29, 2007 Share Posted May 29, 2007 if you are on about the threaded hole in the end of the drive shaft, then a seat belt bolt fits mine... Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted May 29, 2007 Share Posted May 29, 2007 A seat belt bolt is 7/16 UNF, if thats any help. Mo Quote Link to comment Share on other sites More sharing options...
