Ivan Posted October 14, 2005 Share Posted October 14, 2005 Anyone know hwt the thread size is on the output from a RR air suspension compressor ? Also the fitting size for the input to the air tank. TIA Ivan Quote Link to comment Share on other sites More sharing options...
SteveG Posted October 18, 2005 Share Posted October 18, 2005 Hi Ivan Post your Q here and someone like shupack,who has taken his system apart so often will probably know the answer http://www.rangerovers.net/forum/viewforum...1259b3768a905d8 Cheers Steve Quote Link to comment Share on other sites More sharing options...
fisha Posted October 26, 2005 Share Posted October 26, 2005 On the P38, all the air lines are push in 6mm plastic tubing. They are not threaded joins. Quote Link to comment Share on other sites More sharing options...
atomlude55 Posted May 18, 2023 Share Posted May 18, 2023 Aren't they threaded going into the solenoids with compression fittings. Quote Link to comment Share on other sites More sharing options...
hurbie Posted May 18, 2023 Share Posted May 18, 2023 17 years , hows that for a thread revival 1 Quote Link to comment Share on other sites More sharing options...
P38 Paul Posted May 18, 2023 Share Posted May 18, 2023 2 hours ago, hurbie said: 17 years , hows that for a thread revival Who's Fred 😕 Quote Link to comment Share on other sites More sharing options...
Escape Posted May 19, 2023 Share Posted May 19, 2023 16 hours ago, atomlude55 said: Aren't they threaded going into the solenoids with compression fittings. No, all pushfits, the only compression fittings are on the blue line from the compressor to the valve block. Quote Link to comment Share on other sites More sharing options...
