CLANCY Posted July 20, 2007 Share Posted July 20, 2007 Hi all, some advice required.? What would be, if any the benifit of removing the EGR Valve and blanking off,This on my 1996 300tdi Defender 90 120,000 miles Quote Link to comment Share on other sites More sharing options...
peter and hi two minders Posted July 20, 2007 Share Posted July 20, 2007 get rid as much use a s f*rt in bottle and stop all the cr*p going back into the engine. Quote Link to comment Share on other sites More sharing options...
ciderman Posted July 20, 2007 Share Posted July 20, 2007 Blank it off , on the intercooler pipe by cutting the stub off and welding a plate to make the pipe as smooth as possible , any snags will cause a turbulent back pressure . Quote Link to comment Share on other sites More sharing options...
freeagent Posted July 20, 2007 Share Posted July 20, 2007 I removed mine and replaced the intercooler top hose with a piece of exhaust pipe.. I think it made a difference, and looking at the amount of black carp in my intake manifold it was certainly helping to gum up my engine. You are better off without. Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted July 20, 2007 Share Posted July 20, 2007 Search the Discovery forum - it comes up regularly there. Easy to blank off or completely remove, and if it's failed open it's severely impairing your performance and emissions and gumming up your air intake to boot. Quote Link to comment Share on other sites More sharing options...
Projectblue Posted July 20, 2007 Share Posted July 20, 2007 Search the Discovery forum - it comes up regularly there. Easy to blank off or completely remove, and if it's failed open it's severely impairing your performance and emissions and gumming up your air intake to boot. Yup (to above) Took mine out of both 110 & Disco. Not sure on improvement as it was done in conjunction with new intercooler and pump fuelling. You can get blanking plates for the exhaust manifold. Quote Link to comment Share on other sites More sharing options...
white90 Posted July 21, 2007 Share Posted July 21, 2007 the replacement top pipe was £15 and An EGT gauge was fitted to the EGR hole on mine all other electrical items removed and tubes into the Air cleaner-Turbo blocked and sealed Quote Link to comment Share on other sites More sharing options...
CLANCY Posted July 21, 2007 Author Share Posted July 21, 2007 Hi All Some very good advice as always,I will be removing ASAP Thanks again.Trevor Quote Link to comment Share on other sites More sharing options...
