Tachometers
In dreaming mode (it is Saturday after all) and wondering about a VDO tachometer. Bit pricier than I had hoped but also there seem to be two models listed. One, 333-015-009K, does 0-6,000 min and the other, 333-015-010K, does 0-8,000 min.
Two questions. Presumably min is rpm???? Second for a 200Tdi I think I am better off with the 0-6,000 min version but a bit of confirmation would be good.
A friend is also looking for one for his '05 110 which will be a Td5(?) so would the same choice be right for him too?
I am looking at ETB Instruments which I think has been mentioned in a previous thread, or can anyone recommend better/cheaper suppliers?
Thanks and best wishes
Malcy
LR do a Tacho [rev counter] for the Td5, which will be a easy fit & connect to pin 19 of the under drivers seat ecu.
for your 200Tdi use the 0 to 6000 or the 0 to 5000 [LR V8 50th anniversary version] as I have in my 200Tdi 110, easy to fit, connect to earth, W turminal on Alternator for signal & a ignition controlled power supply & gauge illumination.
here
here
here
that should sort you out.
Thanks western
I will pass info on to my friend- he had been quoted £400 by the main stealer. For myself I think I need to prioritise my shopping list which will be hard since it is all must have.
Who knows perhaps someone will commission me to build another database next week and that will sort it all out! More chance of that than winning the lottery - LOL
Malcy
Hmm. I have tried Googling for 5,000 rpm VDO tachometer at 52mm and cannot find anything. Did look at eguages.com and looked as if complex getting in from US, at least from their web site it did anyway.
I like the sound of 5,000 since if max is 4,000 you will get best visual accuracy from the gauge.
Anyone any ideas where I might get one?
Hi there,
I'm getting a VDO tachometer from www.croytec.co.uk - (comes with instructions) have got some great stuff from there before,
he's a good bloke.
LoL
Europa Specialist Parts do the VDO tacho as well....
