dasterdly Posted November 3, 2005 Share Posted November 3, 2005 hello, does anybody have a close up picture of the ATU mounting kits ? Craddocks had them advertised on their website, but on contacting them, they havnt got any ! my ATU came with a single bolt that goes through the wing and connects to the bottom of the case, but far to flimsy it would seem. maybe the little boxes i have seen on the front wings on various defenders/xd's are where the atu sits bolted through ? cheers... Quote Link to comment Share on other sites More sharing options...
muddyplugger Posted November 3, 2005 Share Posted November 3, 2005 My wing boxes went on (and stayed on) no problem with the single bolt. I just put some big washers on to spread the load. From memory I think they had some locating holes too? (Sold the lightweight now so can't check ) They even stood up to driving with the huge aerials on too! B) I dont suppose this photo helps much, but at least it shows they do fit straight on! Quote Link to comment Share on other sites More sharing options...
dasterdly Posted November 3, 2005 Author Share Posted November 3, 2005 My wing boxes went on (and stayed on) no problem with the single bolt. I just put some big washers on to spread the load. From memory I think they had some locating holes too? (Sold the lightweight now so can't check ) They even stood up to driving with the huge aerials on too! B) I dont suppose this photo helps much, but at least it shows they do fit straight on! hello, thanks for the piccy, it helps to get a better idea, and at least if i deciede to fit the atu to the lightweight, i know what it should look like ! still wondering how the defender/xd mount their atu's to the wings ? :-) cheers.. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted November 9, 2005 Share Posted November 9, 2005 still wondering how the defender/xd mount their atu's to the wings ? :-) cheers.. They mount in the same way.... a bolt through the middle and locating pins to stop the ATU box from "rotating" around. They have strengthening plates under the wing panel too, as they're quite heavy and with the length of the antenna on, can cause a nice bit of body damage! Quote Link to comment Share on other sites More sharing options...
dasterdly Posted November 13, 2005 Author Share Posted November 13, 2005 They mount in the same way.... a bolt through the middle and locating pins to stop the ATU box from "rotating" around.They have strengthening plates under the wing panel too, as they're quite heavy and with the length of the antenna on, can cause a nice bit of body damage! cheers for the info, what are the small square shaped boxes on the front wings of alot of ffr's defenders/xd's, i am assuming that they are mounting kits ? or simply cable boxes cheers... Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted November 14, 2005 Share Posted November 14, 2005 cheers for the info, what are the small square shaped boxes on the front wings of alot of ffr's defenders/xd's, i am assuming that they are mounting kits ? or simply cable boxescheers... Yeah, cable boxes IIRC. the cale curls up and gets stuffed into them and there is a little clip on lid. Quote Link to comment Share on other sites More sharing options...
dasterdly Posted November 26, 2005 Author Share Posted November 26, 2005 hello, having found out that the ATU mounts within the cable box on the front wings of ffr landrovers, does anybody have any part numbers ? cheers... Quote Link to comment Share on other sites More sharing options...
western Posted November 27, 2005 Share Posted November 27, 2005 Did you contact my mate, all his details in the PM I sent you. Quote Link to comment Share on other sites More sharing options...
dasterdly Posted November 28, 2005 Author Share Posted November 28, 2005 Did you contact my mate, all his details in the PM I sent you. hello ralph, i emailed him,via the email address you sent me, but had no reply as yet. i have managed to find some part numbers, but not to sure whether the units will fit my ATU, as they are pre defender. i am 90% sure they will but just need some confirmation, then comes the job of aquiring some :-) Cheers... Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted November 28, 2005 Share Posted November 28, 2005 What part numbers do you need? i've got the series 3 and 90/110 FFR parts manuals... Quote Link to comment Share on other sites More sharing options...
western Posted November 28, 2005 Share Posted November 28, 2005 hello ralph, i emailed him,via the email address you sent me, but had no reply as yet. i have managed to find some part numbers, but not to sure whether the units will fit my ATU, as they are pre defender. i am 90% sure they will but just need some confirmation, then comes the job of aquiring some :-)Cheers... Hi, I'll send him a reminder to reply to you the vehicle the mounts are fitted to is a '89 127 rapier tractor. Quote Link to comment Share on other sites More sharing options...
dasterdly Posted November 29, 2005 Author Share Posted November 29, 2005 What part numbers do you need? i've got the series 3 and 90/110 FFR parts manuals... hello jim, the part numbers i have are as follows: PRC 3761 nut plate x2 RRC 3763 support angle x2 RRC 3764 gusset support x1 RRC 3216 mounting bracket A.T.U R/H RRC 3740 reinforcement A.T.U R/H i think there are also a couple of other bits and peices, to complete the mounting kit, but the above should be most of what i need...hopefully :-) cheers... Quote Link to comment Share on other sites More sharing options...
dasterdly Posted November 29, 2005 Author Share Posted November 29, 2005 Hi, I'll send him a reminder to reply to you the vehicle the mounts are fitted to is a '89 127 rapier tractor. cheers ralph... :-) Quote Link to comment Share on other sites More sharing options...
TimeBandit Posted December 3, 2005 Share Posted December 3, 2005 What is the ATU box going to be fitted onto? If it's the Lightweight then don't bother buying the ATU mounting kit for a Defender etc as the didn't use them on the Lightweight. The ATU box is installed basically as you describe in your first post - one big bolt. Quote Link to comment Share on other sites More sharing options...
dasterdly Posted December 4, 2005 Author Share Posted December 4, 2005 What is the ATU box going to be fitted onto? If it's the Lightweight then don't bother buying the ATU mounting kit for a Defender etc as the didn't use them on the Lightweight. The ATU box is installed basically as you describe in your first post - one big bolt. hello, its going to be fitted to my defender, as opposed to the lightweight..which needs..erm..rebuilding ! :-) cheers... Quote Link to comment Share on other sites More sharing options...
TimeBandit Posted December 4, 2005 Share Posted December 4, 2005 hello,its going to be fitted to my defender, as opposed to the lightweight..which needs..erm..rebuilding ! :-) cheers... Ahh...reet...in which case ignore my previous post!! Quote Link to comment Share on other sites More sharing options...
minivin Posted December 9, 2005 Share Posted December 9, 2005 I've got a pair of Defender top wing mounts, freshly satin black powder coated, retention latches in both in one piece (plastic so do break), looking for £30 Amesbury, Wiltshire Quote Link to comment Share on other sites More sharing options...
minivin Posted December 9, 2005 Share Posted December 9, 2005 another piccie: Quote Link to comment Share on other sites More sharing options...
dasterdly Posted December 9, 2005 Author Share Posted December 9, 2005 another piccie: hello, after a couple of weeks of trying to get some information, i have the defender atu mounting kit part number : RTC5948 Dingocroft could supply one for around £60, on contacting somebody differant at craddocks, they assure me that they DO actually have them in stock, and are supposed to be sending me one ! if it dosnt arrive next week, i shall have them off you, providing you still have them ! i will post a reply next week. thanks for all the replys and help. cheers... Quote Link to comment Share on other sites More sharing options...
minivin Posted December 10, 2005 Share Posted December 10, 2005 hello,after a couple of weeks of trying to get some information, i have the defender atu mounting kit part number : RTC5948 Dingocroft could supply one for around £60, on contacting somebody differant at craddocks, they assure me that they DO actually have them in stock, and are supposed to be sending me one ! if it dosnt arrive next week, i shall have them off you, providing you still have them ! i will post a reply next week. thanks for all the replys and help. cheers... no problem, good luck with sorting it out Quote Link to comment Share on other sites More sharing options...
minivin Posted December 11, 2005 Share Posted December 11, 2005 ah, they just sold Quote Link to comment Share on other sites More sharing options...
dasterdly Posted December 14, 2005 Author Share Posted December 14, 2005 ah, they just sold hello, no problem, i recieved the full mounting kit yesterday from craddocks, so it seems they do have them in stock !! £35+vat+£6 p&p cheers... Quote Link to comment Share on other sites More sharing options...
