Cil111 Posted November 15, 2007 Share Posted November 15, 2007 Hi everyone i have a bit of a dilemma... I have an Lt85 santana box and on the manual it says that it should take engine oil as source of lubrication (15/40w) however i have read in some sites that ATF is the one to use.. anyone has any experience of which oil to use? I normally use Engine oil, however i was wondering if i have been putting the wrong oil in my box thanks Quote Link to comment Share on other sites More sharing options...
Mark90 Posted November 15, 2007 Share Posted November 15, 2007 Engine oil (15/40W, 20/40W, or similar) the correct for an LT85, ATF is too thin. An LT77 would use ATF not not an LT85. So you have been using the correct oil. Quote Link to comment Share on other sites More sharing options...
Cil111 Posted November 15, 2007 Author Share Posted November 15, 2007 Engine oil (15/40W, 20/40W, or similar) the correct for an LT85, ATF is too thin. An LT77 would use ATF not not an LT85. So you have been using the correct oil. thanks Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 15, 2007 Share Posted November 15, 2007 Hiya, If you have the proper LT85 then use cheap non synthetic (too sticky) 20/50w engine oil in primary box (1 2 3 4 5 R) and EP90 in transfer Nige PS you have a PM Quote Link to comment Share on other sites More sharing options...
Cil111 Posted November 15, 2007 Author Share Posted November 15, 2007 Nig did not get the gist of the proper LT85 thing..... is there something such as a non proper one? Hope the result of the PM is fine now... thanks for the help Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted November 15, 2007 Share Posted November 15, 2007 Nigdid not get the gist of the proper LT85 thing..... is there something such as a non proper one? Hope the result of the PM is fine now... thanks for the help Sorry me posting too quick By "Proper" I meant that you DEFINATELY have a LT85, you'd be amazed how many get what the gearbox is they have wrong ie LT77 R380 etc, as LT85 is quite rare being V8 90 110s etc. Just saying "If you are sure its a LT85" then its 20/50w, and I have one and use texaco 20/50w as it decent qulaity and cheap Again regular oil changes help, it takes a pounding as does all oil Nige Quote Link to comment Share on other sites More sharing options...
Cil111 Posted November 15, 2007 Author Share Posted November 15, 2007 Sorry me posting too quickBy "Proper" I meant that you DEFINATELY have a LT85, you'd be amazed how many get what the gearbox is they have wrong ie LT77 R380 etc, as LT85 is quite rare being V8 90 110s etc. Just saying "If you are sure its a LT85" then its 20/50w, and I have one and use texaco 20/50w as it decent qulaity and cheap Again regular oil changes help, it takes a pounding as does all oil Nige Oh ok hehe got it now... Yeah definitely a santana box the split case type... always get mixed up if it is a 22a or 22c... well the split type which i think is the more modern version.... if i am not mistaken they also use on the santana PS10 or whatever it is called... the latest model santana have produced... Quote Link to comment Share on other sites More sharing options...
tacr2man Posted November 16, 2007 Share Posted November 16, 2007 I would recommend going to redline Synthetic, its a bit expensive but if you are working it hard behind a V8 (eg heavy towing in hot conditions) its well worth the expense (personal experience) . They ar'nt cheap to rebuild. JMHO Quote Link to comment Share on other sites More sharing options...
