Fatboy Posted November 16, 2007 Share Posted November 16, 2007 Hi, I've recently bought a wreck of a 2a and over the past week or so have stripped all of the major parts off to service / refurb and refit to a new chassis.. Engine will be a V8, I'm currently trying to pluck up the courage to Megasquirt it B) as I'm starting from scratch in so many areas (ripped out naff wiring loom etc). Anyway, tonight I stripped the back axle and found that it didn't have the 10 spline, standard shafts I was expecting.... its got 24 spline jobbies, and they are not standard OD either. At the hub end, the splines are quite long and there is a circlip on the inside of the drive flange as well as the outside. On the diff end, the splines are about 10" long!! The main body OD is actually larger than the spline OD. Any idea what make they are? (No pictures at the moment, camera is at work). Then surprise number 2 was a KAM diff. ..... unfortunately, the pinion has two chipped teeth. Quote Link to comment Share on other sites More sharing options...
western Posted November 16, 2007 Share Posted November 16, 2007 as it's a Kam diff, I'd wager they are Kam's shafts too. Quote Link to comment Share on other sites More sharing options...
Fatboy Posted November 16, 2007 Author Share Posted November 16, 2007 as it's a Kam diff, I'd wager they are Kam's shafts too. Had a look at their website but there are not any good photo's... the ones that are there have shoulders on the inside of the hub end, not continuous splines and circlips. Nice one with the 2min reply by the way Quote Link to comment Share on other sites More sharing options...
bill van snorkle Posted November 18, 2007 Share Posted November 18, 2007 A wild guess as I've never seen a KAM difflock is that the extra long splines are either for the difflock sliding dog clutch to ride on, or KAM make a one size fits all halfshaft that can be cut to suit series lengths with or without Salisbury diff as well as Defender lengths. Bill. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted November 18, 2007 Share Posted November 18, 2007 ISTR that KAM shafts have long splines for the locker to engage on as Bill suspects. Also, if you have identified the diff as KAM then it is almost a certainlty that the shafts are KAM too as it wouldn't function (lock) without them. Nice find - probably worth more than the rest of the truck!! Quote Link to comment Share on other sites More sharing options...
Jon White Posted November 19, 2007 Share Posted November 19, 2007 Kam shafts have long splines on the long shaft only. the short shaft has normal length splines. As someone else says a Kamm locker will not work without KAM shafts so....... Jon Quote Link to comment Share on other sites More sharing options...
Fatboy Posted November 19, 2007 Author Share Posted November 19, 2007 Kam shafts have long splines on the long shaft only. the short shaft has normal length splines.As someone else says a Kamm locker will not work without KAM shafts so....... Jon Thanks all. I'll take photos of all and sundry later just to clarify. I'm stripping the axles to component parts to check / rebuild / paint and I'm glad I have... One rear hub has a stripped thread for the drive flange, one of the others has been tapped out oversize Two wheel studs held in with RTV. Rear diff pinion has two chipped teeth Back axle breather held in with RTV. (threads stripped) Front LH hub only had one nut with the lock tab between it and the spacer!! One stripped wheel stud. Front drive flanges have excessive wear and need replaced.. Swivel housings dry and rusty however UJ's seem okay. Front brakes are 11" drums (LWB?) Quote Link to comment Share on other sites More sharing options...
Tonk Posted November 19, 2007 Share Posted November 19, 2007 Front brakes are 11" drums (LWB?) yes, also fitted to late ser3 swb with servo. Quote Link to comment Share on other sites More sharing options...
