roachy Posted December 19, 2007 Share Posted December 19, 2007 Firstly hello everyone, i'm new to this forum and have already found a wealth of usefull infomation. here goes, I have a 1984 90 pickup with a 2.25 petrol engine and lt77 g'box(i'm pretty sure). i managed to pick up a 300tdi auto disco mot failure with a re-con engine with only 20k on it, wich i have striped and disposed of. i'm pretty confident on how to do the conversion with all the info available on the net. the problem is i dont know weather to use the auto gearbox from the disco or keep my lt77, personally i've never owned an auto and i love manuals but i only use the 90 offroad and greenlaning. any opinions or advice will be muchly appreciated. Also does anyone know if the backplate and flywheel from my 2.25 will fit onto the 300 engine? i also got the rear axle off the disco and it has a 3bolt flange, can i just change the flange with the one off my 90 axle, and is it easy to do? cheers for any info Quote Link to comment Share on other sites More sharing options...
western Posted December 19, 2007 Share Posted December 19, 2007 don't need the parts from the 2.25 engine you can fit a LT77 to a 300Tdi engine here just remove the 4 bolt flange from your existing rear axle & fit it to the Discovery rear axle. Quote Link to comment Share on other sites More sharing options...
roachy Posted December 19, 2007 Author Share Posted December 19, 2007 So my back plate should fit the 300 but i will need the flywheel off the 2.25 as the 300tdi hasn't got a flywheel on it as it's from an auto it has a torque converter. not sure if the flywheel will bolt streight on? Quote Link to comment Share on other sites More sharing options...
western Posted December 19, 2007 Share Posted December 19, 2007 I'm not sure if the flywheel & backplate from the 2.25 engine will fit a 300Tdi, as I never tried to do it. Quote Link to comment Share on other sites More sharing options...
roachy Posted January 5, 2008 Author Share Posted January 5, 2008 Right, i finally decided to keep the manual (LT77) gearbox. Just for anyones future refrence, the 2.25 petrol backplate can be fitted to the 300tdi in two ways, either 1. Remove the 300tdi crankshaft seal and its mounting plate and use the petrol seal (same size crank) 2. Retain the 300tdi crank seal and cut/machine/butcher a D shaped hole in the 2.25 backplate so it fits over the 300 seal mounting plate. (i chose this route as i have access to a machine shop and think the 300 seal is a superior item.) The 2.25 flywheel bolted strait on aswell with no problems, this also allowed me to use the 2.25 starter motor. Quote Link to comment Share on other sites More sharing options...
JST Posted January 5, 2008 Share Posted January 5, 2008 in that case - what do you want for the auto box? personally if you are greenlaning and off roading i would keep the auto, the only way to go i reckon. Quote Link to comment Share on other sites More sharing options...
steve b Posted January 5, 2008 Share Posted January 5, 2008 Hi Roachy, Not sure if the petrol starter will have enough torque for the 300Tdi, and also even though the flywheel fits , it may also be too light for the Tdi . As JST says are you selling the autobox/torque converter/etc? and if so how much...? .....I'm in Suffolk too.. ... Welcome to LR4x4 btw Cheers Steveb Quote Link to comment Share on other sites More sharing options...
roachy Posted January 6, 2008 Author Share Posted January 6, 2008 sorry fellas i don't want to sell it yet as i still might put it in, if i change my mind you'll be the first to know. JST i have heard mixed arguments for and against the auto, (that was the main reason for this thread but not many responses) for ease of fitment i just kept my lt77 for now but im not sure how good that box is. i'm probably going to swap it in the next year either for the auto or an R380 so still need to decide. steve, i was also worried wether the starter would have enough grunt but the 300 one had a different gear so wouldn't work with the flywheel, anyway i turned it over yesterday and it seems fine, yey! also the flywheel is heavy as f**k so it should be fine, mabey a few grams difference but not enough to affect the running of it. where abouts in suffolk? im just outside Sudbury, do you get over Bures pits much? Quote Link to comment Share on other sites More sharing options...
steve b Posted January 6, 2008 Share Posted January 6, 2008 ....Yep, go to Bures regularly to Marshall the Pay and Playdays....I'm based in Stowmarket so mid-suffolk area. I'm the one with the tastefully restored 109sw , caged and twin hydro winchs, hope to see you there sometime B) Cheers Steveb Quote Link to comment Share on other sites More sharing options...
88 Nick Posted January 6, 2008 Share Posted January 6, 2008 [JST i have heard mixed arguments for and against the auto, (that was the main reason for this thread but not many responses) for ease of fitment i just kept my lt77 for now but im not sure how good that box is. i'm probably going to swap it in the next year either for the auto or an R380 so still need to decide. I'D definatly keep the auto if I were you,once your used to it off road you wont regret it,the're a lot kinder to the rest of your transmition too,slight down side is you've gotta keep em cool. Quote Link to comment Share on other sites More sharing options...
JST Posted January 6, 2008 Share Posted January 6, 2008 for serious off roading i would def go for an auto, downsides are the engine braking and overhearting. much kinder on the transmission and much less the think about with no clutch. left for brake, right for accelerator. quicker changes for fwd to rev trying to gain momentum etc and easier to control for tight maneuvers i would have thought. Quote Link to comment Share on other sites More sharing options...
roachy Posted January 7, 2008 Author Share Posted January 7, 2008 cheers for the advice fellas, i had heard that auto's were awesome off road but also that many people prefered a manual, as i already have the auto box i may aswell give it a go later in the year, i can always change it if i don't like it. steve are you going to bures on the 13th? if my truck's finnished by then i'll probably make an apperance, see if i can break it, lol. i've only been there once, had to use the old tow rope a few times, before it snaped then had to enlist the assistance of the nearest unimog. Nothing like getting muddy on the weekend!!! Quote Link to comment Share on other sites More sharing options...
steve b Posted January 7, 2008 Share Posted January 7, 2008 Yep I will be there so if you do make it say hi ...and on the autobox front I'd agree with what has been said , for offroad they can be an advantage, winch and drive being one aspect where they gain over manual - see if you can find someone with an auto to try offroad to get a feel for it... cheers Steveb Quote Link to comment Share on other sites More sharing options...
nas90 Posted January 8, 2008 Share Posted January 8, 2008 Yep I will be there so if you do make it say hi ...and on the autobox front I'd agree with what has been said , for offroad they can be an advantage, winch and drive being one aspect where they gain over manual - see if you can find someone with an auto to try offroad to get a feel for it...cheers Steveb nas V8 auto................................................ Quote Link to comment Share on other sites More sharing options...
