twizzle Posted January 21, 2008 Share Posted January 21, 2008 Has any body got a good diagram of disco 200Tdi front loom TWIZZLE Quote Link to comment Share on other sites More sharing options...
nige90 Posted January 21, 2008 Share Posted January 21, 2008 I could scan in the page from the Haynes for the 90 if it will help. Quote Link to comment Share on other sites More sharing options...
Jon White Posted January 22, 2008 Share Posted January 22, 2008 Er............why??? Theres so few wires on a 200tdi it'll not be of much use to you. Plus a 200 disco is wired up kind of strangely. Easiest just to re-use what was there on the series surely? Thats what i did when i shoved a 200 disco lump into my series. I carefully removed the whole disco loom to swap accross but ended up throwing it away as it wasnt really much use at all! Cheers Jon Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 22, 2008 Share Posted January 22, 2008 I carefully removed the whole disco loom to swap accross but ended up throwing it away as it wasnt really much use at all! I'm sure that'll please Twizzle as he's meticulously saved the entire Disco front end loom and swapped it across... Quote Link to comment Share on other sites More sharing options...
Jon White Posted January 22, 2008 Share Posted January 22, 2008 I'm sure that'll please Twizzle as he's meticulously saved the entire Disco front end loom and swapped it across... D'oh!!!!! Quote Link to comment Share on other sites More sharing options...
twizzle Posted January 23, 2008 Author Share Posted January 23, 2008 D'oh!!!!! you can go off some people Quote Link to comment Share on other sites More sharing options...
western Posted January 23, 2008 Share Posted January 23, 2008 Has any body got a good diagram of disco 200Tdi front loom TWIZZLE will check my RAVE info for you & see whats there. only 300Tdi wiring info, no 200TDi Sorry Quote Link to comment Share on other sites More sharing options...
twizzle Posted January 23, 2008 Author Share Posted January 23, 2008 will check my RAVE info for you & see whats there.only 300Tdi wiring info, no 200TDi Sorry western THANK'S for trying it's only the front part of the loom as my 109's loom was a tad not there and if i want to take the wing's off, i can pull on the loom connector(photoed) TWIZZLE Quote Link to comment Share on other sites More sharing options...
Jon White Posted January 24, 2008 Share Posted January 24, 2008 Errrrrrrrr.............thats a fuel filter............ Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 24, 2008 Share Posted January 24, 2008 Errrrrrrrr.............thats a fuel filter............ He means the two connectors to the right of it Quote Link to comment Share on other sites More sharing options...
Jon White Posted January 24, 2008 Share Posted January 24, 2008 D'oh! Didnt spot them when I looked at the thumbnail......... Quote Link to comment Share on other sites More sharing options...
