trogers Posted March 19, 2008 Share Posted March 19, 2008 Hi all Can anyone tell me if you can buy the nylon rollers that run along the tracks of the electric window mechanism. Mine decided to self destruct screwing the arm in the process. I managed to straighten the arm out and push the middle back into the roller but only a temp job. I hope I don't have to replace the whole mechanism. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
landi41 Posted March 19, 2008 Share Posted March 19, 2008 Hi allCan anyone tell me if you can buy the nylon rollers that run along the tracks of the electric window mechanism. Mine decided to self destruct screwing the arm in the process. I managed to straighten the arm out and push the middle back into the roller but only a temp job. I hope I don't have to replace the whole mechanism. Thanks in advance. Not to be a smartass here.... but it would be helpfull if you could tell us what model and year Discovery you drive.......(It's easy to put it in your signature) as for the rollers, i doubt very much they are available separately but a good machinist, with a bit of Teflon stock could build you new ones....... Quote Link to comment Share on other sites More sharing options...
Ryan Posted March 19, 2008 Share Posted March 19, 2008 I can't seem to find it as a separate part on Microcat. I think it will mean a trip to your local scrapyard. Quote Link to comment Share on other sites More sharing options...
cipx2 Posted March 19, 2008 Share Posted March 19, 2008 Here are som solutions from down under: - http://www.aulro.com/afvb/projects-tutoria...air-waynep.html - http://www.aulro.com/afvb/technical-chatte...ear-window.html I go with what landi41 suggested. You can even make your own if you have some teflon or high density polyethylene and a drill driver/machine. Quote Link to comment Share on other sites More sharing options...
scrumps Posted March 20, 2008 Share Posted March 20, 2008 Here are som solutions from down under:- http://www.aulro.com/afvb/projects-tutoria...air-waynep.html - http://www.aulro.com/afvb/technical-chatte...ear-window.html I go with what landi41 suggested. You can even make your own if you have some teflon or high density polyethylene and a drill driver/machine. HI, This happened recently on my sandbags TD5 Disco. You can get just the regulator from a firm in Bournemouth via E-blag for about Thirty quid. All you have to do is swap over the motor (which is why it's a lot cheaper that the Land Rover part which comes complete). Look for Part no. CUH102300 (RH) from seller "3u2". Regards Scrumps Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 20, 2008 Share Posted March 20, 2008 A complete new window regulator is very cheap. The electric motor doesn't come with it though, but it's dead easy to swap it over. Les. Quote Link to comment Share on other sites More sharing options...
teabag Posted March 21, 2008 Share Posted March 21, 2008 A complete new window regulator is very cheap. The electric motor doesn't come with it though, but it's dead easy to swap it over.Les. Back in 03 a LR dealer charge me £64 + vat for a (supply only) n/s/f regulator not so cheap then. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 21, 2008 Share Posted March 21, 2008 You'd expect that kind of price from a dealer. Fortunately you can get them from the likes of Bearmach for about half that. Les. Quote Link to comment Share on other sites More sharing options...
trogers Posted March 27, 2008 Author Share Posted March 27, 2008 Here are som solutions from down under:- http://www.aulro.com/afvb/projects-tutoria...air-waynep.html - http://www.aulro.com/afvb/technical-chatte...ear-window.html I go with what landi41 suggested. You can even make your own if you have some teflon or high density polyethylene and a drill driver/machine. Hi cipx2 This fix was great, carried it out to the letter and it works brilliantly. Thanks for the 5x info. trogers. Quote Link to comment Share on other sites More sharing options...
rovernaut Posted March 28, 2008 Share Posted March 28, 2008 Hi cipx2This fix was great, carried it out to the letter and it works brilliantly. Thanks for the 5x info. trogers. I replaced the broken roller with a piece of flat nylon. It doesn't need to be a roller, a slide will work as well it has lasted for year so far. I posted this repair method on another site years ago . roller repair Quote Link to comment Share on other sites More sharing options...
