Unusual Split Rim Wheels
Topple
I bought some unusual split rim wheels at the weekend. Inboard and outboard wheel halves are joined by eight tie bolts and each rim has six substantial lugs.
Can anyone identify these wheels, what vehicle they're from and what the lugs are for ?
Thanks
Are the lugs original?
Could they be for some kind of tyre chain or wheel track system given that they are on both inside and outside of the rim. I remember seeing photos of 21/2 ton GMC trucks in WW2 having twin wheels fitted on all axles and individual wheel tracks on each duel wheel.
My first impressions were that the lugs are an original feature but I suppose it's hard to tell. If they are a retrofit it was done well. They're equispaced, well aligned and nicely welded. I did wonder if they could be for chains as you suggest but i've never seen them before.
They look very like Austin Champ split rims to me. There used to be a metal plate on the outer rim with a WD (War Dept) Part Number. I'd also guess that the lugs are for chains.
Thanks for your suggestion. There are definately some plates on them so i'll take a look in daylight.
