DaveA Posted April 1, 2008 Share Posted April 1, 2008 After recently stripping down the fuel regulator following repeated mis-fires and regulator leaks, I found that the fuel "strainer" was full of paper / fluff, which looked like paper from the fuel filter element. I know that the filter operates under fuel pressure (60psi?). Has anybody experienced any similar problems ? Is the genuine filter a better buy ? Quote Link to comment Share on other sites More sharing options...
woff Posted April 1, 2008 Share Posted April 1, 2008 I'm doing my regulator soon as it is leaking so I'll have a look and report back. Don't sound good cause I use britpart fuel filters as well. Quote Link to comment Share on other sites More sharing options...
freeagent Posted April 2, 2008 Share Posted April 2, 2008 I wouldn't buy a Britpart one, i've had loads of grief with their stuff. try Coopers, they make OEM filters for loads of people.. good compromise between cheap carp (Britpart) and overpriced genuine parts. Quote Link to comment Share on other sites More sharing options...
woff Posted April 2, 2008 Share Posted April 2, 2008 Am I mis-understood I was hoping that the britpart LandRover Replacement was better than a cooper/fram? I've just serviced my td5 and used britpart filters but that is because I've never had a problem. Quote Link to comment Share on other sites More sharing options...
freeagent Posted April 2, 2008 Share Posted April 2, 2008 I've had enough grief with Britpart stuff to know i wouldn't trust one of their 'wing-wong manufacturing company' filters as the only line of defence for my injection pump. Coopers have been arround for years, as have Fram... i'd be deeply suspicious of anything Britpart were selling. What about a Bosch fuel filter? do they do them for Td5's? Quote Link to comment Share on other sites More sharing options...
sotal Posted April 2, 2008 Share Posted April 2, 2008 I agree with freeagent, stay well clear of the britpart stuff. I had a britpart fuel filter for the 300tdi and it was carp, bought it as I was desperate for one, but it fitted badly and looked ****, I ordered a better one at the same time - can't remember make - then picked that up a few days later and threw the britpart one in the bin Quote Link to comment Share on other sites More sharing options...
BogMonster Posted April 2, 2008 Share Posted April 2, 2008 I have seen problems with even some of the well known makes of filter in cold conditions with iffy diesel that is slightly prone to waxing. All I can say is that fitting a Genuine filter seemingly cured it. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted April 2, 2008 Share Posted April 2, 2008 We tend to use what our supplier can supply. The latest lot are Britpart instead of Cooper and we have had no problems. Quote Link to comment Share on other sites More sharing options...
thebiglad Posted April 3, 2008 Share Posted April 3, 2008 I use Britpart filters on both of our Disco's with no ill effects whatever. Due to there cheap price £7 for a kit of air, oil and fuel filters, I change them all every 5000mls. Quote Link to comment Share on other sites More sharing options...
roguevogue Posted April 3, 2008 Share Posted April 3, 2008 Might not be down to biodiesel then? Quote Link to comment Share on other sites More sharing options...
DaveA Posted April 3, 2008 Author Share Posted April 3, 2008 Might not be down to biodiesel then? Very observant! I did run some bio for a bit, and blocked up a couple of filters. It just seemed strange that the bits blocking the strainer looked just like paper particles. I have read various articles about bio "cleaning" out fuel lines & blocking filters, but the filter itself ? I do now know that the TD5 is a bit more fickle about its fuel that the 300 was, which would run on just about anything ! You learn by your mistakes ... Quote Link to comment Share on other sites More sharing options...
