draper40 Posted April 14, 2008 Share Posted April 14, 2008 Hey, Lots of people are talking about using really useful boxes for storage. Which sizes boxes do you use and where do you put them? Pete Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 14, 2008 Share Posted April 14, 2008 24L size, x4, mounted in the back, plus a long one to hold socket set, breaker bar, crowbar and other bits that don't fit in normal ones. The wire frame is my new improved retention system, I will add a couple of bits to keep the long one in place, the beauty is it's just one bungee to hold the boxes in place. Quote Link to comment Share on other sites More sharing options...
Mark Posted April 14, 2008 Share Posted April 14, 2008 I use 35L ones, and I put them in the back of my disco: Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 14, 2008 Share Posted April 14, 2008 I noticed them in Staples last week. They look very good. If I didn't have Wolff boxes I'd be going for those. mike Quote Link to comment Share on other sites More sharing options...
Orange Posted April 14, 2008 Share Posted April 14, 2008 One of the best things about them is that they are square inside (well, rectangular, but you know what I mean!!) so they are easy to pack. Most of the cheaper Tesco/B&Q items have rounded internal corners so you end up with loads of wasted space. I can also stand on mine, which is quite a feat as I'm not a small chap!! I, too, use the 35L ones and 2 of them fit comfortably between the wheel arches of the 90. I will be on the lookout for a wide shallow box in the near future (like Fridgefreezer has) to store long stuff in, but also to put under the other 2 so that I can secure them down better. At the moment, they are only about 1.5" above the wheel arch box so holding them down is a bit tricky... Quote Link to comment Share on other sites More sharing options...
denviks Posted April 14, 2008 Share Posted April 14, 2008 i have 2 of these bolted in the rear of my 110. not sure on size but i know they are heavy and very strong. at the moment they are green but will spray them soon. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted April 15, 2008 Share Posted April 15, 2008 I've got two 18L boxes side by side between the wheelboxes, they fit under the edge of the bench seats. To be honest, they were a temporary solution, 4 years ago. They've lasted well, been used as seats and steps, I finally killed one when i rested the end of an axle on it, it took 10 miles to break though, my fault for not moving them!! Quote Link to comment Share on other sites More sharing options...
