letsgetdirty Posted April 18, 2008 Share Posted April 18, 2008 hi all,just wanted to share one of those fab ebay moments,i know you all are most likeley in bed but i won a huge pair of spotlamps brand new for 99p!! couldnt believe it! theyre making there way onto the landy as soon as i get chance,i have a relay already but wondered if any one could explain simply how to wire them,i tend to struggle with wiring,thanks and kind regards to all!! Quote Link to comment Share on other sites More sharing options...
Tris Cocks Posted April 19, 2008 Share Posted April 19, 2008 hi all,just wanted to share one of those fab ebay moments,i know you all are most likeley in bed but i won a huge pair of spotlamps brand new for 99p!! couldnt believe it! theyre making there way onto the landy as soon as i get chance,i have a relay already but wondered if any one could explain simply how to wire them,i tend to struggle with wiring,thanks and kind regards to all!! What a bargin, with my spots i ran a cable from the battery to pin 30 on the relay which is mounted under the front wing, and from number 87 to my spots (both of which using 2.5mm² cable). the other to terminals on the relay should be labled 85 and 86. take a cable from 85 down to ground (or back to the battery) this leaves terminal 86 for the switch, for mine i took it to the light stalk for the main beam (IIRC blue with a white stripe) to make this legal you should then have a switch in line with the main beam so that the spots can be isolated from the main lighting system. HTH Tris Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted April 19, 2008 Share Posted April 19, 2008 Hurumph... The last time that I managed to grab a 99p bargain, the seller suddenly discovered that it was damaged after the auction was over and so couldn't complete the deal.. (yeah, right...). Quote Link to comment Share on other sites More sharing options...
Milemarker Type S Posted April 19, 2008 Share Posted April 19, 2008 What a bargin, with my spots i ran a cable from the battery to pin 30 on the relay which is mounted under the front wing, and from number 87 to my spots (both of which using 2.5mm² cable). the other to terminals on the relay should be labled 85 and 86. take a cable from 85 down to ground (or back to the battery) this leaves terminal 86 for the switch, for mine i took it to the light stalk for the main beam (IIRC blue with a white stripe) to make this legal you should then have a switch in line with the main beam so that the spots can be isolated from the main lighting system.HTH Tris As ^^^^^^ but remember to put a suitably sized fuse in the main live feed from the battery as close to the battery as possible. Quote Link to comment Share on other sites More sharing options...
Tris Cocks Posted April 19, 2008 Share Posted April 19, 2008 forgot to mention about the fuse, it is possible to get scotch lock type connectors with a built in blade fuse holder, only a quid or so i think. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted April 19, 2008 Share Posted April 19, 2008 Bodgelok connectors are the work of the devil, no ifs, no buts! Fit them only if you want a vehicle electrical fire - and if it goes up in smoke, don't come back here, you'll get 'I told you so' Here's a diagram for wiring up a relay. Quote Link to comment Share on other sites More sharing options...
Tris Cocks Posted April 19, 2008 Share Posted April 19, 2008 Dont mean to hyjack the thread but what dont you like about scotchloks? Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted April 19, 2008 Share Posted April 19, 2008 Dont mean to hyjack the thread but what dont you like about scotchloks? in short......because they're cr@p. They're the equivalent of using cable ties where nuts & bolts should be. do a proper job; cut the cable, crimp on a spade or better still solder the wires and use heat shrink/self amalgamating tape. Quote Link to comment Share on other sites More sharing options...
letsgetdirty Posted April 19, 2008 Author Share Posted April 19, 2008 What a bargin, with my spots i ran a cable from the battery to pin 30 on the relay which is mounted under the front wing, and from number 87 to my spots (both of which using 2.5mm² cable). the other to terminals on the relay should be labled 85 and 86. take a cable from 85 down to ground (or back to the battery) this leaves terminal 86 for the switch, for mine i took it to the light stalk for the main beam (IIRC blue with a white stripe) to make this legal you should then have a switch in line with the main beam so that the spots can be isolated from the main lighting system.HTH Tris Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted April 20, 2008 Share Posted April 20, 2008 Excuse my ignorance, but are Scotchloks those fold-over plastic things with connections for two wires on one side and one on the other, with a steel bridge that pushes through the wires to make the contact? Quote Link to comment Share on other sites More sharing options...
denviks Posted April 20, 2008 Share Posted April 20, 2008 Excuse my ignorance, but are Scotchloks those fold-over plastic things with connections for two wires on one side and one on the other, with a steel bridge that pushes through the wires to make the contact? thats the ones mate Quote Link to comment Share on other sites More sharing options...
