landybear Posted May 7, 2008 Share Posted May 7, 2008 Hi all, I am trying to work out what is 'clicking' when i turn left. I have looked underneath and nothing is loose. It seems to be under the left hand side of vehicle like under where passengers feet goes. Anyone had this before? At first i thought battery knocking but that is secured? It sounds like your jaw clicking in and out!! Thats the only way to describe it. Cheers Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 7, 2008 Share Posted May 7, 2008 CV joint on the way out would be my guess, the prop UJs are also worth a look but they would make a noise all the time Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 7, 2008 Share Posted May 7, 2008 I agree with Boggy The CV's are about to become toast. Les. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 7, 2008 Share Posted May 7, 2008 So are you if you keep calling me Boggy sunshine Quote Link to comment Share on other sites More sharing options...
110_USA Posted May 8, 2008 Share Posted May 8, 2008 Thats similar to what I heard when my bearings went out, was most severe during turning but would happen occasionally just going straight. Quote Link to comment Share on other sites More sharing options...
landybear Posted May 8, 2008 Author Share Posted May 8, 2008 Cheers for the replies guys. Anyway of checking the CV to make sure or not? Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted May 8, 2008 Share Posted May 8, 2008 If it's not the obvious things like tyres on the radius arms, or the prop UJs, there's not really anything else it could be. failing CVs make a pretty distinctive sound. As has been said, they sound worse when you've got some lock on. By the time you've stripped down the hub and swivel to look at the CV, you might as well replace it. FWIW, when my CVs failed, the sound was worse in reverse than going forward. Quote Link to comment Share on other sites More sharing options...
