300tdi downpipe removal
bigjohn
hi all,
i am changing all the exhaust system on my 300tdi manual.do i need to remove any crossmembers or rollbars to get the downpipe out(cat type)?.i am changing to non cat downpipe.i am happy tonight as i got the 3 turbo nuts off without anything snapping !!.refit tomorrow night all being well.cheers,john.
As above, remove front ARB, and jack the vehicle up on the chassis to extend the gap between the axle and the chassis... it'll come out fairly easily...
Agreed, i did one yesterday, lift the chassis only to give a bigger gap between the axle and chassis, easy peasy then.
All done now,with help from above (no jokes :rolleyes: )we managed to remove the old downpipe without removing any other parts,the non cat downpipe went in easier than the cat one came out.i think using the flexi downpipe helped with the fitting,maybe dropping the ARB would be needed to fit the solid type.
So far EGR removed,cat removed, cambelt next !!
cheers, john.
