bigjohn Posted May 13, 2008 Share Posted May 13, 2008 hi all, i am changing all the exhaust system on my 300tdi manual.do i need to remove any crossmembers or rollbars to get the downpipe out(cat type)?.i am changing to non cat downpipe.i am happy tonight as i got the 3 turbo nuts off without anything snapping !!.refit tomorrow night all being well.cheers,john. Quote Link to comment Share on other sites More sharing options...
cipx2 Posted May 13, 2008 Share Posted May 13, 2008 Dropping the front anti-roll bar should be enough. Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted May 14, 2008 Share Posted May 14, 2008 You may find it helps to lift the chassis slightly to improve the clearance above the axle. Quote Link to comment Share on other sites More sharing options...
freeagent Posted May 14, 2008 Share Posted May 14, 2008 As above, remove front ARB, and jack the vehicle up on the chassis to extend the gap between the axle and the chassis... it'll come out fairly easily... Quote Link to comment Share on other sites More sharing options...
Skanny Posted May 14, 2008 Share Posted May 14, 2008 As above, remove front ARB, and jack the vehicle up on the chassis to extend the gap between the axle and the chassis... it'll come out fairly easily... Agreed, i did one yesterday, lift the chassis only to give a bigger gap between the axle and chassis, easy peasy then. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted May 14, 2008 Share Posted May 14, 2008 As above, remove front ARB, and jack the vehicle up on the chassis to extend the gap between the axle and the chassis... it'll come out fairly easily... Why remove the locker? Quote Link to comment Share on other sites More sharing options...
auf_wiedersehen_pet Posted May 14, 2008 Share Posted May 14, 2008 Why remove the locker? Anti Roll Bar? Quote Link to comment Share on other sites More sharing options...
bigjohn Posted May 14, 2008 Author Share Posted May 14, 2008 All done now,with help from above (no jokes )we managed to remove the old downpipe without removing any other parts,the non cat downpipe went in easier than the cat one came out.i think using the flexi downpipe helped with the fitting,maybe dropping the ARB would be needed to fit the solid type. So far EGR removed,cat removed, cambelt next !! cheers, john. Quote Link to comment Share on other sites More sharing options...
RRX Posted May 14, 2008 Share Posted May 14, 2008 Solid type on mine, jacked the chassis up a bit but old one came out no trouble and new one in no probs Quote Link to comment Share on other sites More sharing options...
