draper40 Posted May 21, 2008 Share Posted May 21, 2008 Hey, What are the differences between spraying a metallic paint and a normal one as I am looking at respraying the 90 in bonatti grey using a air powered spray gun. Also where do I find a paint code for this paint? Pete Quote Link to comment Share on other sites More sharing options...
kpodmore Posted May 21, 2008 Share Posted May 21, 2008 sure someone else will answer with more detail but for that i think you use a two pack paint and a laquer coat on top. not sure how easy it is to to as a home spray Quote Link to comment Share on other sites More sharing options...
flocks Posted May 21, 2008 Share Posted May 21, 2008 I have just home sprayed my 110csw in bonnatti grey it was the first time that i had sprayed metallic and it wasn't all that bad i got some good advice from my local paint supplier with regards to thinners etc and it all went on fine, i finished it all off with 8 coats of clear it has been 5 days since i finshed it so i can compound it this weekend but it has a great shine already. Quote Link to comment Share on other sites More sharing options...
paintman Posted May 21, 2008 Share Posted May 21, 2008 Metallic and/or pearlescent paints comprise the base coat which is the colour coat - and a clear lacquer sprayed over the top. The base coat dries matt & it's the clearcoat that gives the shine so you need two lots of materials plus thinner/hardener etc. What ever paint you get ask for the Technical Data sheets (examples at http://corporateportal.ppg.com/Refinish/Ma...D/3000_TDS.html )as these have all necessary info as to pressure, thinning, drying times ete etc AND safety info re breathing protection. Not difficult to use - but I do it every day! Bonatti Grey code is LAL Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 22, 2008 Share Posted May 22, 2008 If you use Cellulose-based paint it all comes in one tin and you don't have to use laquer. To get an even coat you need to occasionally shake the spray gun to keep the paint mixed. The metal particles will continually try to settle to the bottom, so you need to keep them in suspension. Les. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted May 22, 2008 Share Posted May 22, 2008 The metal particles will continually try to settle to the bottom, so you need to keep them in suspension.Les. But don't use orange suspension, or they'll definately sag to the bottom.... Quote Link to comment Share on other sites More sharing options...
draper40 Posted May 22, 2008 Author Share Posted May 22, 2008 Any recommendations of where to get paint from around me? Pete Quote Link to comment Share on other sites More sharing options...
draper40 Posted May 22, 2008 Author Share Posted May 22, 2008 ^^^^the in the can cellulose stuff? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 22, 2008 Share Posted May 22, 2008 Ford metallic azure blue in cellulose- Les. Quote Link to comment Share on other sites More sharing options...
ciderman Posted May 22, 2008 Share Posted May 22, 2008 I thought they no longer made cellulose paint products ? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 22, 2008 Share Posted May 22, 2008 It's had a stay of execution apparently. At least you can still buy it. The replacement is water-based, which prevents you from killing fluffy bunnies and baby sparrows. It's just mega-expensive to buy. Les. Quote Link to comment Share on other sites More sharing options...
paintman Posted May 22, 2008 Share Posted May 22, 2008 Where did you get the paint from Les? & this is definitely cellulose & hasn't got a lacquer clearcoat over it? Quote Link to comment Share on other sites More sharing options...
michael calvert Posted May 23, 2008 Share Posted May 23, 2008 metalic takes 3 or 4 passes to get the cover, where as with standard 'flat' colours you can coover the panel in one, a matter of building up the 'layers' with each pass the mist covers over and over till all the panel is coloured.... .....have i just confused it or does that make sense? think of colouring in with a felt tip, where you go over a previous line you get that horrible lap with metalic you get something similar Quote Link to comment Share on other sites More sharing options...
draper40 Posted May 23, 2008 Author Share Posted May 23, 2008 That looks great Les, where is a good place to get the paint? Pete Quote Link to comment Share on other sites More sharing options...
