Rightfoot Posted May 21, 2008 Share Posted May 21, 2008 Hi, I've just picked up a set of 35x10.5x16 Simex Extremes fitted to TX Performance Alloys without tubes, and will be seeing how they go on Saturday at Walters Arena. I've read a whole load of threads about pressuring down, single beadlocks, twin beadlocks, Staun Beadlocks, spinning inner tubes if pressures are too low etc. etc., which are all very interesting but I haven't got any of these So how low can I go and stand a reasonable chance of not popping the bead? Quote Link to comment Share on other sites More sharing options...
Les Brock Posted May 21, 2008 Share Posted May 21, 2008 Used to run mine at 18 Psi, but be aware that with the increased grip and large rocks at 7S watch your half shafts and CV's If you run standard stuff ! Quote Link to comment Share on other sites More sharing options...
Steve 90 Posted May 21, 2008 Share Posted May 21, 2008 As Les says 18. I used to run no less than 16-18 before beadlocks. Anything less and I kept pushing tyres off rims. At 16 you'll still do it but much less often. 18 seems pretty reliable. Fitting tubes stopped them being pushed off but kept ripping valves off then! Quote Link to comment Share on other sites More sharing options...
TJ101 Posted May 21, 2008 Share Posted May 21, 2008 Ditto as Les & Steve,, ran at 16 and pulled 2 off the rims, upped them to 18, and so far have been ok !! Remember to have a play in the water at 7S, as per my avatar !! Quote Link to comment Share on other sites More sharing options...
landrover598 Posted May 21, 2008 Share Posted May 21, 2008 I run my 32" simex at 16 psi without problems yet. Quote Link to comment Share on other sites More sharing options...
LR90 Posted May 21, 2008 Share Posted May 21, 2008 18 front, 15 rear.... and a bit less when off road Quote Link to comment Share on other sites More sharing options...
will_warne Posted May 22, 2008 Share Posted May 22, 2008 A lot depends on the weight of your truck. Mine had eaten quite a lot of pies and I found 18 - 20 worked well (tubeless). Any less and you will start popping them off rims. Quote Link to comment Share on other sites More sharing options...
Rightfoot Posted May 22, 2008 Author Share Posted May 22, 2008 Thanks everyone - 18 it seems to be I'll find out on Saturday if you're right Quote Link to comment Share on other sites More sharing options...
