letsgetdirty Posted June 21, 2008 Share Posted June 21, 2008 Hello people, Something has been bugging me for a while now, I placed a second spare wheel on my bonnet, There are a few things Im unsure of, Firstly It was meant as kind of an enhancement but a few defender drivers have quiet blunty said it looks pants, As i dont really need and Im not sure of how it looks would you guys please tell me your opinions? Secondly as fuel is so expensive and the defenders used a lot would this effect fuel consumption?? Thirdly my tyres are 265 75 16, And my spares are still the original 205s, In the event of a puncture would this cause damage or increased wear to the axles etc on a long run home?? Its not a vital topic but Id love to hear what some of you think. Kindest regards to all tris Quote Link to comment Share on other sites More sharing options...
muddy Posted June 21, 2008 Share Posted June 21, 2008 Well it wont be helping the aerodynamics, mine is only on the bonnet as its a pick up and i need all the load bay and theres no way its going on the roof rack. As for looks well i'm not too bothered myself, it bugs me that its not the same size/tread/wheel as the 4 on it but its only tempary (honest ) Maybe it would look better with a cover on the spare?? Just my 2p worth. Will. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 21, 2008 Share Posted June 21, 2008 letsgetdirty, A spare wheel on the bonnet can be a pain for a couple of reasons in my opinion. They block the view immediately in front of you, not a problem on the road where you are looking ahead but off road a problem because that's the bit you need to see. Secondly, they make the bonnet flippin' heavy and a bit of an ordeal to open. They do look a bit pants to me but it's a subjective thing Don't use vastly different sized tyres (like 205s and 265s) on your Landy (apologies to MOG) unless you want the diff to have a very short life. You'll need to buy a spare of the correct size. HTH Mo Quote Link to comment Share on other sites More sharing options...
letsgetdirty Posted June 21, 2008 Author Share Posted June 21, 2008 Thanks for that so far fellas, It is bloomin heavy, The bonnet creaks and groans every time its opened to, Im glad I found out about the damage that could be done MO , And muddy it does bug me its a different size to, But a cover is a good idea. Hmmmm think I can see where this is going. tris Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 21, 2008 Share Posted June 21, 2008 I'd buy something the right size because that looks a bit daft IMHO. I don't think a proper spare on the bonnet looks bad or affects the aerodynamics / MPG significantly. It will block your view off-road a bit and make the bonnet heavy to open, plus the bigger/heavier the tyre the more fun it is lifting it down, which is why I don't keep my spare up there anymore Quote Link to comment Share on other sites More sharing options...
letsgetdirty Posted June 21, 2008 Author Share Posted June 21, 2008 I'd buy something the right size because that looks a bit daft IMHO. Thanks fridge, what does imho mean tho Quote Link to comment Share on other sites More sharing options...
ollie nz Posted June 21, 2008 Share Posted June 21, 2008 Hello people, Something has been bugging me for a while now, I placed a second spare wheel on my bonnet, There are a few things Im unsure of, Firstly It was meant as kind of an enhancement but a few defender drivers have quiet blunty said it looks pants, As i dont really need and Im not sure of how it looks would you guys please tell me your opinions? Secondly as fuel is so expensive and the defenders used a lot would this effect fuel consumption?? Thirdly my tyres are 265 75 16, And my spares are still the original 205s, In the event of a puncture would this cause damage or increased wear to the axles etc on a long run home?? Its not a vital topic but Id love to hear what some of you think. Kindest regards to all tris PUT THE GRILL BACK ON,AND A COVER ON THE WHEEL,VERY SMART.I WOULDN'T WORRY ABOUT FUEL CONSUMPTION,YOUV'E GOT SO MANY TOYS HANGING OFF IT NOW,I DON'T THINK THE WHEEL WILL MAKE MUCH DIFFERENCE. Quote Link to comment Share on other sites More sharing options...
letsgetdirty Posted June 22, 2008 Author Share Posted June 22, 2008 Cheers ollie, Might not get the grill on because of the winch but mesh is an option. I Loves me toys!! tris Quote Link to comment Share on other sites More sharing options...
Guest wunntenn Posted June 22, 2008 Share Posted June 22, 2008 The spare wheel on the bonnet creates a vortex behind it when you are driving which makes the windscreen wash water go everywhere except the windscreen so I wouldn't worry too much about what it looks like, just enjoy it for the moment because come winter you're going to run into something that you didnt see and demolish the front because your windscreen was covered in crud. :-) Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 22, 2008 Share Posted June 22, 2008 what does imho mean tho In My Humble Opinion The windscreen washer thing is easily solved by either fitting wiper-mounted jets, or the poor man's version - run the washer tube up the arm, block the end and make some <1mm holes that point screenwards with a pokey thing. I used some .8mm welding wire heated with a lighter last time, that was a field fix though. Quote Link to comment Share on other sites More sharing options...
muddy Posted June 22, 2008 Share Posted June 22, 2008 I used some .8mm welding wire heated with a lighter last time, that was a field fix though. Just like the rest of the truck then Makes for the coat stand..... Quote Link to comment Share on other sites More sharing options...
