wozza35 Posted July 12, 2008 Share Posted July 12, 2008 Does anyone know of a repair panel that is available for the bottom of defender doors or know of anyone in my area (Taunton/Bridgwater,Minehead) who repairs them at a reasonable cost or even someone who has some for sale Quote Link to comment Share on other sites More sharing options...
GL88 Posted July 12, 2008 Share Posted July 12, 2008 First define 'reasonable' and then what precisely needs doing. Assuming that it is the bottom rail of the steel subframe then in Frome is this mob http://www.landroversuk.co.uk/ who advertise on eBay at £100 per door plus VAT (excluding repainting cost) currently item 320273537356. Or if you want to have a go yourself YRM sell replacement door frame bottom rails http://www.yrm-metal-solutions.com/ . If the door skin is looking a bit like lace then probably more economical to get a new door. Quote Link to comment Share on other sites More sharing options...
wozza35 Posted July 12, 2008 Author Share Posted July 12, 2008 Thanks gl88 ,i have seen landrovers uk on ebay but im sure i heard that they are not very good and it is mainly the bottom rail Quote Link to comment Share on other sites More sharing options...
Blippie Posted July 12, 2008 Share Posted July 12, 2008 ... and you can pick up reasonable doors at autojumble/eBay for £100 a door. Cheers Blippie Quote Link to comment Share on other sites More sharing options...
dirkthe1 Posted July 12, 2008 Share Posted July 12, 2008 cant you cut out the rusted (im geussing its rust-but mines the same) parts, brace it and then put chequer plate on top? but mine are the militray split types, with no liner theres nothing you cant fix with an angle grinder Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted July 12, 2008 Share Posted July 12, 2008 theres nothing you cant fix with an angle grinder Profound thought Mo Quote Link to comment Share on other sites More sharing options...
dirkthe1 Posted July 12, 2008 Share Posted July 12, 2008 its true. they taught me that at college! Quote Link to comment Share on other sites More sharing options...
GL88 Posted July 13, 2008 Share Posted July 13, 2008 Wozza, sorry should have said I've not experience of the mob in Frome. I've sorted out corrosion in a door frame on my SIII myself using odd bits of steel from B&Q and daresay it will last longer than the original. I've also had bits from YRM and they are very good. But you need welding gear for both options (which I have). And I've got to sort the rear door on my TD5 and really must ensure I do it before the winter - I'll be using a YRM bottom rail for that and hope to be so careful that I shan't need to get it sprayed (and pigs might, etc ...). Quote Link to comment Share on other sites More sharing options...
wozza35 Posted July 14, 2008 Author Share Posted July 14, 2008 Thanks Gl ,i have seen the YRM panels before and wondered if they were any good ,i will have to get one and see what i can do Quote Link to comment Share on other sites More sharing options...
Orange Posted July 14, 2008 Share Posted July 14, 2008 ... and you can pick up reasonable doors at autojumble/eBay for £100 a door.Cheers Blippie If you do find some, you're best to buy them and put them into stock! The last pair I saw at Capel were £225 and they were almost worse than the ones I've got on the truck already!! Quote Link to comment Share on other sites More sharing options...
