crazyfarmerboy Posted September 9, 2008 Share Posted September 9, 2008 hello thier is a 110 for sale with a v8 and lpg conversion. however it needs a new chassis. it is worth while sorting if i xan get it for a couple of hundred pounds. do you know how enconomic it will be with a gas conversion and how much it will be worth. it is a c reg by the way so that is about 1984. thanks guys Quote Link to comment Share on other sites More sharing options...
white90 Posted September 9, 2008 Share Posted September 9, 2008 could end up spending lots on lots of bits/pieces I'd say not worth it unless you fancy a project Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 9, 2008 Share Posted September 9, 2008 A new chassis will set you back a load of cash, and be a load of work - and you'll find all the other seized, rusted, and broken stuff on the way through. It'll end up costing loads. Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted September 9, 2008 Share Posted September 9, 2008 Who says it needs a new chassis? Can it not be patched repaired by a competant person? It depends on what you want it for. If you want a concourse vehicle then maybe it will be a lot of work. If you want a runaround veh then not necessarily so. If you want an offroader then even less. It will depend on your skill set and how much work you are willing to do or farm out. Plus if it needs new panels are youprepared to put second hand parts on or only new. At the end of the day only you know what you are capable of. A chassis change needn't be that painful. If you have access to lifting gear then you can lift the whole body off in 1 go. Thereby negating the need to strip it down to it's bare bones. And undoing loads of nuts + bolts unneccessarily. If you can get it for a few hundred quid, could you not buy it break it to make more money to get another veh that more suits you? The gas kit will be worth a few quid and then comes the axles, engine, body panels etc etc. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 9, 2008 Share Posted September 9, 2008 Unless you weld yourself, patching a chassis can cost almost as much as a new one ! Mo Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 10, 2008 Share Posted September 10, 2008 Unless you weld yourself, patching a chassis can cost almost as much as a new one ! And you're still left with a very old, crusty chassis that is just going to keep on rusting and needing patches. Quote Link to comment Share on other sites More sharing options...
Exmoor Beast Posted September 10, 2008 Share Posted September 10, 2008 Never underestimate the cost of nuts and bolts and odds and ends. I've just spent £1000 on my 110 and it still looks dreadful. Having said that, £1300 for a new chassis, £1500 for odds and ends + say £300 to buy the original 110 + 6 months hard work and you would have a 110 for life Will Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 10, 2008 Share Posted September 10, 2008 I've just spent £1000 on my 110 and it still looks dreadful. Yes, but it always has Les Quote Link to comment Share on other sites More sharing options...
