Turbocharger Posted September 16, 2008 Share Posted September 16, 2008 I need a 180mm diameter P-clip to hold my new air filter box into the car. It'll probably stay where it's put just held by the hoses but it'd be neater to strap it down. Any pointers on suppliers? Quote Link to comment Share on other sites More sharing options...
carl hurst Posted September 16, 2008 Share Posted September 16, 2008 You may need to have one made at a fab shop, never seen one so big, Carl. Quote Link to comment Share on other sites More sharing options...
Milemarker Type S Posted September 16, 2008 Share Posted September 16, 2008 What about using one or two of the large quickfists from Si at X-Eng... Would be ideal. linky... He does a forum discount as well! Quote Link to comment Share on other sites More sharing options...
MECCANO Posted September 17, 2008 Share Posted September 17, 2008 Thats a really good idea, but how would they stand up to the heat of an engine bay? Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted September 17, 2008 Author Share Posted September 17, 2008 I think that's a non-starter already since I've not really got room around the back of the engine for the filter box, a P-clip's pushing it so a QF would mean lopping a hole in the bulkhead and putting the filter by the gearstick! Looks like I'll be buying some strip steel... Quote Link to comment Share on other sites More sharing options...
clbarclay Posted September 17, 2008 Share Posted September 17, 2008 One of the techniques used at work for holding or holding onto large diameter parts is to use band clamps (AKA jubilee clips etc.) which go around the round part and a tab on the other part. Having said that big band clamps arn't exactly cheap. Quote Link to comment Share on other sites More sharing options...
callum Posted September 17, 2008 Share Posted September 17, 2008 you'd probably be best making your own out of flat bar or a strip of sheet. for holding down pipes in my engine bay 54mm dia. i just made my own. bend a tab with a hammer in a vice and then carefully rolled the bar around the object to be clamped. as mine were holding pipes out in space i could tap the flat section for the tightening bolt to thread into. (...well i could have, but i mixed up my drill bit sizes and made the hole too big to tap so had to just use a nut instead) Quote Link to comment Share on other sites More sharing options...
bishbosh Posted September 17, 2008 Share Posted September 17, 2008 John, I have some really big jubilee clips - like 1m long!! Free to your good self. Can sling them in the car if you are interested....? Or, try Western Hose and industrial - they do rubber lined p clips in all sorts of sizes. Quote Link to comment Share on other sites More sharing options...
