roybatty666 Posted October 18, 2008 Share Posted October 18, 2008 Well after the ongoing brake saga following fitting my truetrac diff and tdi300 hubs I thought I would take a break and ft the front Llama4x4 kit after the ease of slapping on the rear. Dispite having to split the nut off the old damper all went well until I want to put the Coolant tank back on and the longer shock turret is in that way. Now this must be a common issue so there must me an equally obvious soloution...... ..... unfotunatly it is not jumping out at me at the moment It is on a 1990 90 with a disco 200tdi with the air filter cylinder on the passanger side Is there another tank I can use? Still I am a few steps further along and my saggy 18 year old springs and heavy winch + bumper aren't causing my nose to be on the floor old Now Quote Link to comment Share on other sites More sharing options...
Steve 90 Posted October 18, 2008 Share Posted October 18, 2008 I have the earlier, small steel tank (as opposed to the large plastic 200TDi style) with a little bit of alteration of the bracket it still fits as std. Gwyn did say they need to be moved a bit when I was speaking to him one day. Quote Link to comment Share on other sites More sharing options...
western Posted October 18, 2008 Share Posted October 18, 2008 make up a new mount for the header tank so it sits clear [further into the engine bay] of the damper mount. Quote Link to comment Share on other sites More sharing options...
roybatty666 Posted October 18, 2008 Author Share Posted October 18, 2008 make up a new mount for the header tank so it sits clear [further into the engine bay] of the damper mount. I suppose some studding with two sets of nuts on each could locate the top 2 mounts and then move the original bottom one Quote Link to comment Share on other sites More sharing options...
Timmy511 Posted October 19, 2008 Share Posted October 19, 2008 im sure gwyn said he did a kit to relocate it when i bought mine. Quote Link to comment Share on other sites More sharing options...
roybatty666 Posted October 19, 2008 Author Share Posted October 19, 2008 I have currently adjusted (see bent) the inner mounting bracket in a bit so the tank is sitting inside the shock tower and then used 2 zip ties to hold it in place, surprisingly sturdy for a temporary fix I will have a word with Dave at Llama4x4 tomorrow as it is all his fault as he gets his kit off Gwyn so may also have what I need Any pics of peoples home grown mounting plates etc would be nice to see Quote Link to comment Share on other sites More sharing options...
bishbosh Posted October 20, 2008 Share Posted October 20, 2008 Huh? Since when have zip ties been a temporary fix on land rovers...? I used the original TD metal reservoir. It clears the top of the shock by 1/4 inch max Quote Link to comment Share on other sites More sharing options...
