Max Series-3 Posted October 22, 2008 Share Posted October 22, 2008 I want to fix my series mechanically. The guy i bought it from had this from paddocks: Part Number: 214649 Description: Track rod end rubber boot Quantity: 4 Unit Price: 0.99 (GBP) Part Number: 241380 Description: Bump stop Quantity: 4 Unit Price: 2.21 (GBP) Part Number: 276484 Description: Propshaft gaiter kit Quantity: 2 Unit Price: 1.91 (GBP) Part Number: 568858P Description: Steering Damper Bush - Polyurethane Quantity: 4 Unit Price: 0.50 (GBP) Part Number: 577898 Description: Track Rod End Clamp inc nut and bolt Quantity: 4 Unit Price: 1.00 (GBP) Part Number: 591039 Description: Brake drum Quantity: 4 Unit Price: 8.45 (GBP) Part Number: BLR34WH Description: Land Rover Series 3 Official Workshop Manual Quantity: 1 Unit Price: 24.95 (GBP) Part Number: CP001G Description: Heavy Duty Series 2/2A/3 88 Inch Galvanised Chassis - NOT ELIGIBLE FOR FREE DELIVERY Quantity: 1 Unit Price: 680.00 (GBP) Part Number: DA4162 Description: de Carbon Gas Shock Abs - Front Quantity: 2 Unit Price: 34.50 (GBP) Part Number: DA4163 Description: de Carbon Gas Shock Abs - Rear Quantity: 2 Unit Price: 34.50 (GBP) Part Number: FRC4907 Description: Rear propshaft SWB Quantity: 1 Unit Price: 37.36 (GBP) Part Number: GB5603 Description: Automec Brake Pipe Kit - Series 3 SWB 88in no servo - RHD Quantity: 1 Unit Price: 42.75 (GBP) Part Number: PM959 Description: Heavy Duty Steering Rods Quantity: 2 Unit Price: 72.50 (GBP) Part Number: PRB/NUT Description: Propshaft Nut and Bolt Quantity: 16 Unit Price: 0.20 (GBP) Part Number: RTC5867 Description: Track rod end/grease nipple (replacement) RH thread Quantity: 2 Unit Price: 3.74 (GBP) Part Number: RTC5867G Description: Track rod end (Lemforder - O.E.M.) RH thread Quantity: 2 Unit Price: 6.50 (GBP) Part Number: RTC5868 Description: Track rod end/grease nipple (replacement) LH thread Quantity: 2 Unit Price: 3.74 (GBP) Part Number: RTC5868G Description: Track rod end (Lemforder - O.E.M.) LH thread Quantity: 2 Unit Price: 6.50 (GBP) Part Number: SDLR04B Description: Series SWB Deflex Polyurethane Bush Kit - inc. shock abs bushes. (standard orange) Quantity: 1 Unit Price: 40.00 (GBP) Part Number: STC121 Description: Front propshaft SWB/LWB 4cyl Quantity: 1 Unit Price: 37.49 (GBP) Part Number: STC786B Description: Bilstein B6 Steering Damper Quantity: 2 Unit Price: 39.95 (GBP) Part Number: SWBKIT1 Description: Brake Overhaul Kit - SWB to 1981 Quantity: 1 Unit Price: 39.95 (GBP) Total Price: 1,365.98 (GBP) What do you think that i can get away without e.g the chassis is really bad so is a new one the only option? Any suggestions would be most helpfull! Thanks max Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted October 23, 2008 Share Posted October 23, 2008 Errr just from a quick scan down the list you can save £473.35 straight away by removing the following... DeCarbon Gas shocks - use OEM ones much cheaper Brake kit - buy the pipe and unions and a tool and DIY, then you have the tool for next time HD steering rods - sleeve yours with appropriate size tube or carry a spare, second hand ones are v cheap Series manual - nope, download it for free Deflex bushes - use OEM then you wont need to replace them every 2 weeks Steering damper - use OEM Props - dunno what the sliding joint is like but if its ok just put new OEM UJs in That should keep you busy for a while! And dont forget all those prices are + VAT!!!! Mike Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted October 23, 2008 Share Posted October 23, 2008 The track rod ends specified seem to be duplicated, (Replacement v OEM) I don't see you need both types. I wouldn't argue against Mike's suggestions, but do add that it may be beneficial to run the remaining part numbers through http://www.LRseries.com, which might bring the cost down some more. Have fun! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 23, 2008 Share Posted October 23, 2008 Deflex bushes - use OEM then you wont need to replace them every 2 weeks The OE ones may be longer lasting but I run Deflex and reckon they're reasonable value, and changing them is considerably easier than OE ones. £40 for a full vehicle kit is hardly breaking the bank. Propshaft gaiters I wouldn't bother with (likewise swivel gaiters or shock boots), there are two schools of thought - fit gaiters to keep things clean, or don't fit them so you can inspect, clean, and grease as necessary. Quote Link to comment Share on other sites More sharing options...
Jon White Posted October 23, 2008 Share Posted October 23, 2008 Only replace whats worn IMHO and then only with standard replacements. If it aint worn out dont replace it. You'll save a heap of money that way. Decarbon shocks are totally unsuitable for a series. If you're on stock leaves then run stock shocks. If you're on parrotsbollox than pro-comps. Dont bother with HD steerin rods. They're well protected on a series and in all the years I've had my truck (I've done winch challenges with it etc) I've only ever bent one! I simply keep a spare one zip tied to the rool cage. Download the manual for free off the net. Dont bother with prop gaitors as they just fill up with mud. Do you really need new drums all round???? Etc etc etc. Like I said - only replace what needs to be replaced! Jon Quote Link to comment Share on other sites More sharing options...
