clarkie2772 Posted October 26, 2008 Share Posted October 26, 2008 hi I am planning to cut a window in the left hand side of my 90 truckcab, to improve my visibility whilst driving in France. I have sourced a glass and rubber from a renault express, but I will have to cut into the lateral reinforcing bar in the truckcab. Can anyone give me any tips in this procedure, ( can I simply cut the hole with a jigsaw? ) all the best Marc Quote Link to comment Share on other sites More sharing options...
western Posted October 26, 2008 Share Posted October 26, 2008 if tha's your 90 in your avatar, it's a hardtop not a truckcab, just carefully measure twice & cut once, the rib in the side panel can be removed completly as the new window will stiffen the side panel once the window is fitted. Quote Link to comment Share on other sites More sharing options...
clarkie2772 Posted October 26, 2008 Author Share Posted October 26, 2008 if tha's your 90 in your avatar, it's a hardtop not a truckcab, just carefully measure twice & cut once, the rib in the side panel can be removed completly as the new window will stiffen the side panel once the window is fitted. I knew it was a hardtop Quote Link to comment Share on other sites More sharing options...
OilIT Posted October 26, 2008 Share Posted October 26, 2008 I knew it was a hardtop as western says drill thru the spotwelds on the strengthener and remove - then measure - ideally measure the apperture in a renault master if this is where the glass is coming from. mark it out with soft pencil - check & double check. when yr happy drill hole in corner then its best to use an air nibbler imho. Quote Link to comment Share on other sites More sharing options...
TheHarv Posted October 26, 2008 Share Posted October 26, 2008 there was a step-by-step write up (with pics) in LRM Issue 109 (Aug 07) http://www.lrm.co.uk/Back%20Issues/2007/2007.08.html Quote Link to comment Share on other sites More sharing options...
jameslwt Posted October 26, 2008 Share Posted October 26, 2008 The problem with a jigsaw (as I found) is the vibration makes it quite difficult. I have done it twice now: once with a nibbler attached to a drill - v easy but messy, and a sabre saw which was just as good. Quote Link to comment Share on other sites More sharing options...
clarkie2772 Posted October 26, 2008 Author Share Posted October 26, 2008 thanks all whats a nibbler? sh@t I'm useless Quote Link to comment Share on other sites More sharing options...
