landydave Posted December 22, 2008 Share Posted December 22, 2008 I've got some brtipart folding side steps but no fitting instructions. I suspect it might not be that straightforward as i've got rocksliders on. Can anyone give me any intructions/pics on how they're meant to fit. It's just an interim until i can afford some tubulars. Dave Quote Link to comment Share on other sites More sharing options...
TJ101 Posted December 22, 2008 Share Posted December 22, 2008 Dave These may help Gen Defender side step Fitting Quote Link to comment Share on other sites More sharing options...
Steve Warman Posted December 22, 2008 Share Posted December 22, 2008 When I fitted mine I found the tank under the drivers side was in the way sufficiently for me to drill through fromt he inside of the drivers floor and put some bolts through. Lucky for me some previous owner had put the nutserts into the chassis rails Quote Link to comment Share on other sites More sharing options...
landydave Posted December 22, 2008 Author Share Posted December 22, 2008 DaveThese may help Gen Defender side step Fitting Tim, cheers but i can't get that link to work. Dave Quote Link to comment Share on other sites More sharing options...
landydave Posted December 22, 2008 Author Share Posted December 22, 2008 Tim, cheers but i can't get that link to work.Dave scratch my last. got to it. Dave Quote Link to comment Share on other sites More sharing options...
TJ101 Posted December 22, 2008 Share Posted December 22, 2008 Tim, cheers but i can't get that link to work.Dave OK,, see if THIS WORKS then go into Defender ,, Accessory Fitting Instructions ,Continue,,,Click ALL Years,, then ACCESS then Ref: STC8015AA Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted December 22, 2008 Share Posted December 22, 2008 I have sliders on and fitted some folding side steps, there should be upside down u shaped channels running along the edge under the doors between the wheel arches, if you line the chassis leg of the step up with the lower bolt, if you have these channels in place still then the holes on the vertical faces of the legs will line up with holes in the channel. I put some M8 bolts through these which did the trick. On the drivers side (1988 90) the fuel tank was in the way as someone else has mentioned, so I too drilled some holes beside the driver's seat under the metal panel that screws into the seat box base, this allowed me to fit two bolts into the horizontal feet of the steps which had slightly better access. The metal plate then screws back down over the bolt heads and hides them. That was how I did it anyway, a tree stump removed the driver's side one so they're no longer fitted now and I can't take pictures to describe what I mean. Quote Link to comment Share on other sites More sharing options...
TJ101 Posted December 22, 2008 Share Posted December 22, 2008 Dave's tank is in the rear, ie TD5 Quote Link to comment Share on other sites More sharing options...
JST Posted December 23, 2008 Share Posted December 23, 2008 Dave i think the southdown sliders will be in the way of where the vertical section of the step needs to go - same for tubular sills as well - may be wrong though. i do have the original side sills if you want them if you end up replacing the southdown sills, wouldnt mind first dibs back on the southdown sills though. Alternative - weld a step on to the sills just dont make it too strong so that it at least bends if you catch it off roading rather than it becoming an extra anchor point. Quote Link to comment Share on other sites More sharing options...
landydave Posted December 26, 2008 Author Share Posted December 26, 2008 Dave i think the southdown sliders will be in the way of where the vertical section of the step needs to go - same for tubular sills as well - may be wrong though.i do have the original side sills if you want them if you end up replacing the southdown sills, wouldnt mind first dibs back on the southdown sills though. Alternative - weld a step on to the sills just dont make it too strong so that it at least bends if you catch it off roading rather than it becoming an extra anchor point. All sorted now. They fit on just fine after a bit of manouvering. I think if i ever did any serious offroading i'd just unbolt them, but until then at least the girlfriend can get up into the cab! Dave Quote Link to comment Share on other sites More sharing options...
JST Posted December 27, 2008 Share Posted December 27, 2008 thats good news - well done Quote Link to comment Share on other sites More sharing options...
Markoteal Posted December 5, 2012 Share Posted December 5, 2012 I'm about to tackle the same challenge but can't get the link above to work - anyone else got a similar link I could look at? Ta Quote Link to comment Share on other sites More sharing options...
Pastycrimper Posted December 6, 2012 Share Posted December 6, 2012 I have square rocksliders and I fitted the Britpart side step.......it wouldn't go completely vertically into the back position because of the sliders but its not far off and is fine for me. Quote Link to comment Share on other sites More sharing options...
