suveer Posted December 28, 2008 Share Posted December 28, 2008 hi all, i see oil leaking through the wading plug hole in the bell housing of my 1997 300tdi disco 1. Will it be the oil from the main box or something else that is seeping from somewhere. thanks Quote Link to comment Share on other sites More sharing options...
R Bates Posted December 28, 2008 Share Posted December 28, 2008 It's probably the rear crank seal Quote Link to comment Share on other sites More sharing options...
pinny Posted December 28, 2008 Share Posted December 28, 2008 hi all,i see oil leaking through the wading plug hole in the bell housing of my 1997 300tdi disco 1. Will it be the oil from the main box or something else that is seeping from somewhere. thanks if its from the engine its comong through the crank seal this oil would be black if its coming from the gbox/transferbox it would be either atf red or stinky gear oil is it a lot of oil or just a wte patch around the hole Quote Link to comment Share on other sites More sharing options...
filthy Posted December 28, 2008 Share Posted December 28, 2008 If you have a Disco that does not leak from the wading plug hole, then you have no oil in the engine . . . . . seriously, I've had 7 Disco's & they all leaked a little from the crank seal. to test how much, fit a wading plug for a week & then catch what comes out when you remove it. If it's a desert spoon full, then ignore it until you change the clutch & even if it's more - ignore it unless your clutch slips. We have 3 Discos & simply have a few shovels of sand under the area below the engines when parked. Rule of thumb . . . . . there is no such thing as a Disco that does not leak. Filthy Quote Link to comment Share on other sites More sharing options...
DiscoStu Posted December 29, 2008 Share Posted December 29, 2008 Mine was the gearbox input shaft seal. Full gearbox out job for a £4 (from the dealer!!) part. http://forums.lr4x4.com/index.php?showtopi...;hl=input+shaft Stu. Quote Link to comment Share on other sites More sharing options...
First_Fleet Posted December 29, 2008 Share Posted December 29, 2008 To my mind, an oil seal lip should need to leak through within reason, otherwise the mating rubbing surfaces would not be lubricated. If it didn't, the seal lip would just "burn" out through friction. So, a little weeps? Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted December 29, 2008 Share Posted December 29, 2008 I agree in a way FF, but I have seen the occasional main seal on 300Tdi and V8 engines that did not leak enough for any oil to come out of the wading plug hole. The seal is concave where it runs on the crankshaft and maybe a little oil sits in there. Mine, like most, leaks a drop every day or two (and has done for years). Quote Link to comment Share on other sites More sharing options...
suveer Posted December 29, 2008 Author Share Posted December 29, 2008 thanks guys. I will first try to figure out what oil is leaking, is it the ATF (red) or engine oil. If its the crank seal, must the whole engine come off? thanks for all your help. Quote Link to comment Share on other sites More sharing options...
