davidfox123 Posted January 7, 2009 Posted January 7, 2009 If I remove all suspension arms/panhard rod so that I can take them to have new bushes pressed in will the axles move out of line? Obviously won't move it once they're off! Quote
western Posted January 7, 2009 Posted January 7, 2009 Yes, you will have to realign the axles/arms/chassis brackets to refit the newly bushed arms/rod. Quote
russ3120 Posted January 7, 2009 Posted January 7, 2009 as Western says, they will move and its a royal pain in the butt to get the arms back in. If you chock all the wheels tightly then it should make lif a bit easier, but your axl stll may twist Quote
bishbosh Posted January 7, 2009 Posted January 7, 2009 Try this. Hand brake on in diff lock. Chock the rear wheels. Support the front axle on axle stands. Support the diff nose with a third stand or a jack. Remove arms and panhard. The axle shouldn't move but the body will move laterally when the panhard rod is removed but this is easily dealt with when you refit. Change the bushes, and refit. Peasy! Quote
Reiny Posted January 8, 2009 Posted January 8, 2009 Work on one arm at a time. The twisting will be limited. Assist the arms in using a small bottle jack and you should have no problems. I've done it this way countless times and never experienced any problems whatsoever. Quote
Les Henson Posted January 8, 2009 Posted January 8, 2009 The nose of the diff will drop, but that can be prevented with a jack or axle stand (or easily jacked back into alignment. Removing the panhard rod allows the body to move towards the passenger side by about 40mm. Removing both radius arms makes the axle move forwards. Put the chassis on axle stands with the wheels still on the ground. Chock both wheels - in front and behind. Place a jack under the nose of the diff, and then remove the panhard rod and radius arms. The body will still move sideways, but everything else should stay in line more or less. If the axle moves forward, it's a pig to get it to line-up again. Les. Quote
