discomikey Posted January 9, 2009 Share Posted January 9, 2009 my rear shocks need replacing, i was considering some pro comp +2" shocks will it lift my landy as i dont really need it lifted, i just want more articulation. is it the springs that lift it and will i need dislocation cones to guide my standard springs back in place? cheers mikey Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted January 9, 2009 Share Posted January 9, 2009 The shocks won't affect the ride height. It's the springs that set the ride height. You may well need dislocation cones as the axle will be able to drop lower, also you will probably need longer brake lines for the same reason. HTH Pete. Quote Link to comment Share on other sites More sharing options...
stageonesimmo Posted January 9, 2009 Share Posted January 9, 2009 I wouldn't buy pro-comps again - the paint finish dies within weeks and the damper shaft was rusty/pitted within about the same time - poor quality as far as I'm concerned, when mine snap or give up I'm going for Terra-Firma all round. Performance-wise though theyre good kit, just a shame they aren't built/finished very well. And Pete's spot on............ Quote Link to comment Share on other sites More sharing options...
discomikey Posted January 9, 2009 Author Share Posted January 9, 2009 cheers, ill probably take purchase in a more standard shock then, will 110 shocks fit it or are the mounts different? mikey Quote Link to comment Share on other sites More sharing options...
muddy Posted January 9, 2009 Share Posted January 9, 2009 I woull look at raised shock mounts whilst you are buying new shocks seen as thos long shocks are the same price as short ones. Quote Link to comment Share on other sites More sharing options...
discomikey Posted January 9, 2009 Author Share Posted January 9, 2009 I woull look at raised shock mounts whilst you are buying new shocks seen as thos long shocks are the same price as short ones. sorry im thick and didnt quite understand that could you possibly simplify it for me cheers mikey Quote Link to comment Share on other sites More sharing options...
Dunc Posted January 9, 2009 Share Posted January 9, 2009 Mikey, Buy the cheap standard replacement shocks from M&M4X4. Mine cost me about a tenner each and lasted 3 years. Ample. Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted January 9, 2009 Share Posted January 9, 2009 i put +2 shocks on my 90 it's made the 90 better off road but have a look at my post about pro comps http://forums.lr4x4.com/index.php?showtopi...mp;hl=pro+comps Quote Link to comment Share on other sites More sharing options...
dave t Posted January 10, 2009 Share Posted January 10, 2009 I just fitted a set of standard height Monroe gas shocks to my disco and considering they are only 24 quid each I am well pleased with the result. Cant say the same for the Britpart steering damper though, only been on there a week and I am getting steering judder!!! Dave Quote Link to comment Share on other sites More sharing options...
