pritch1 Posted February 12, 2006 Share Posted February 12, 2006 Anyone up to the challenge of trying to diagnose this ****** noise driving me crazy. send me your emails and ill send the video over to you i really cant work it out of u might of heard it before. Thanks matt Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted February 12, 2006 Share Posted February 12, 2006 Anyone up to the challenge of trying to diagnose this ****** noise driving me crazy. send me your emails and ill send the video over to you i really cant work it out of u might of heard it before.Thanks matt give is a clue, where from engine wheels axle ?....Nige Quote Link to comment Share on other sites More sharing options...
pritch1 Posted February 12, 2006 Author Share Posted February 12, 2006 cant quite work it out only on hill climbs. think it might be from transfer box region but can not be sure its dam annoying though. the other strange noise is a load whine when traveling at over 50 on the road. just want to make sure i fix the right bits Quote Link to comment Share on other sites More sharing options...
western Posted February 12, 2006 Share Posted February 12, 2006 Go on then my e.mail in my profile a few more clues as where on the vehicle it's coming from will help Quote Link to comment Share on other sites More sharing options...
GBMUD Posted February 12, 2006 Share Posted February 12, 2006 Go on then, send me the vid. My email Chris Quote Link to comment Share on other sites More sharing options...
GBMUD Posted February 12, 2006 Share Posted February 12, 2006 I can't make it out. Sounds like someone saying "A-hay" to me. Oh, the squealing noise? Some damage to the exhaust perhaps? Does it happen on the road at all? Chris Quote Link to comment Share on other sites More sharing options...
pritch1 Posted February 12, 2006 Author Share Posted February 12, 2006 nah doesnt do it on the road and cant see any signs of damage etc. i was possibly thinking centre diff. has got worse since the arb rear locker. ps. it wasnt the way hey i was trying to figure out Quote Link to comment Share on other sites More sharing options...
white90 Posted February 12, 2006 Share Posted February 12, 2006 check the oil in the swivels/diff wheel bearing shot check for any foreign objects aroung tthe brake discs front output flange dust shield make sure it isn''t touching the transfer box. Quote Link to comment Share on other sites More sharing options...
white90 Posted February 12, 2006 Share Posted February 12, 2006 also jack the front up and run it in gear to see if the noise is up front then try it with the rear in the air. Quote Link to comment Share on other sites More sharing options...
western Posted February 12, 2006 Share Posted February 12, 2006 Had a listen, it sounds like something rubbing, could be a bent disc dust shield or prop flange guard, but they would do it at all times, most likely the centre diff or transfer box low range gear or bearings. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted February 12, 2006 Share Posted February 12, 2006 I can't make it out. Sounds like someone saying "A-hay" to me. Chris Perhaps you've got an Alan Partridge stuck in there somewhere? Quote Link to comment Share on other sites More sharing options...
pritch1 Posted February 12, 2006 Author Share Posted February 12, 2006 with it happening only on steep climbs it has sort of ruled a few of these out although i will jack up the front and rear of the car and get it running. Is it possible to be gearbox instead of transfer box. do you think the centre diff would make this sort of noise when under heavy load. Quote Link to comment Share on other sites More sharing options...
