BigSi110 Posted February 1, 2009 Share Posted February 1, 2009 This is on behalf of Megansfolly, who is currently in a workshop somewhere in Buckinghamshire... He's fitted a 200Tdi into his 90 and his trying to prime the system with the hand pump on the lift pump. When he does this, fuel spurts out of the underneath of the cambelt case. Is this a sign of the injector pump needing new seals and if so, what's involved making the repair? Or what else could be causing the fuel leak? Any help gratefully recieived. Quote Link to comment Share on other sites More sharing options...
western Posted February 1, 2009 Share Posted February 1, 2009 sounds like either a missing crush washer on the fuel inlet pipe from the lift pump or a internal seal in the injection pump, as the injection pumps are made to fine tolerances I wouldn't recommend stripping it in a standard garage enviroment, would be best removed & taken to a diesl injevtion specialist for repair/recalibration. as if any dirt even the smallest bit will cause untold damage to the pump. Quote Link to comment Share on other sites More sharing options...
white90 Posted February 1, 2009 Share Posted February 1, 2009 http://forums.lr4x4.com/index.php?showtopi...mp;#entry157623 #Fuel spurting out sounds more like a loose connection. Quote Link to comment Share on other sites More sharing options...
BigSi110 Posted February 1, 2009 Author Share Posted February 1, 2009 Thanks gents! Much appreciated. I'll pass this on and get him to poke his nose in here as soon as. Quote Link to comment Share on other sites More sharing options...
Megansfolly Posted February 1, 2009 Share Posted February 1, 2009 cheers guys right i ll try and expalin it now when lift pump is pumped by hand fuel enters the injection pump and then pours out and in to cambelt hosuing no fuel escaping from pump that can be see from out side bit once cam belt cover is of u can see it pouring out from behind the cog so i take it is this seal thats gone second question as cambelt is covered in diesel do i need ot change it? Quote Link to comment Share on other sites More sharing options...
western Posted February 1, 2009 Share Posted February 1, 2009 Yes, sort the injection pump out & replace the timing belt & make sure the casing is absolutly clean & dry before fitting the new belt. otherwise in a short period you'll be in there again. 200Tdi's seem to be gentle on thier timing belts, everyone Ive changed has looked in very good condition with no wear on the edges only minute cracks around the teeth when the belt is turned over & bent on itself. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 2, 2009 Share Posted February 2, 2009 You can buy and replace the seal yourself - it's not really any different from replacing any other seal, although the lip can be turned accidentally quite easily. You'll have to replace the belt - the fuel makes it weak. Les. Quote Link to comment Share on other sites More sharing options...
Megansfolly Posted February 2, 2009 Share Posted February 2, 2009 many thanks any ideas where i can get the seal from and is this what is coursing my problem Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 2, 2009 Share Posted February 2, 2009 Sometimes the seal just wears out, or the shaft rusts, which creeps under the lip of the seal and accellerates wear. Check there's no play in the shaft itself (if there is - you'll have to get it fixed or replace the pump). The injector pump seal is a Delphi Item (no part number I'm afraid). I did a thread on how to replace the inj pump shaft seal on a TD engine (pretty-much the same job), it seems to have disappeared though. Les. Quote Link to comment Share on other sites More sharing options...
Megansfolly Posted February 2, 2009 Share Posted February 2, 2009 les i have that printed out and have found one as well which is also in tech archive but in french which i have found a version thats not frnch but cant post it something about Sorry, dynamic pages in the tags are not allowed Quote Link to comment Share on other sites More sharing options...
perv Posted February 2, 2009 Share Posted February 2, 2009 The disco 200tdi pump is a Bosch VE unit, I can get you the part number for the seal tomorrow or Ping me your address and i can pop 1 in the post. Ash...... Quote Link to comment Share on other sites More sharing options...
Megansfolly Posted February 3, 2009 Share Posted February 3, 2009 you have a pm mate Quote Link to comment Share on other sites More sharing options...
perv Posted February 3, 2009 Share Posted February 3, 2009 Got it dude, will be in the post on wednesday. Quote Link to comment Share on other sites More sharing options...
Megansfolly Posted February 3, 2009 Share Posted February 3, 2009 can u get the key for the key way as well it flew out when the flange finally moved Quote Link to comment Share on other sites More sharing options...
perv Posted February 3, 2009 Share Posted February 3, 2009 No woodruff key fitted to those pumps mate. If you check the drive flange you will not find a grove either. You should have locked the shaft in place with the locking/clamping bolt on the side of the pump with the timing hole in the correct position ( 9.5mm pin ) then removed the flange. Now you will have to re-time the pump drive...... Quote Link to comment Share on other sites More sharing options...
Megansfolly Posted February 3, 2009 Share Posted February 3, 2009 i had pin in but it flew out when flange came off just been and looked think i ve buggered up have take pics flange is just a cylider bo pumps or dents and pump shaft deffo has key way slot Quote Link to comment Share on other sites More sharing options...
perv Posted February 4, 2009 Share Posted February 4, 2009 Yes as your photo shows the shaft has a slot for the key but this only used for reference IE; to set the pump timing, The key way is lined up with the correct cylinder then plunger lift is measured fron the 12mm headed bolt hole between the 4 injector outlets. If you can borrow a DTI gauge and fitting you can set this up your self !!!!!! Quote Link to comment Share on other sites More sharing options...
Megansfolly Posted February 5, 2009 Share Posted February 5, 2009 many many thanks i scored a line on the pump shaft and the flange so i hope i can line the score line up and press the flange on, what torque does the nut need to be. i owe you big time for this Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 5, 2009 Share Posted February 5, 2009 There's no listing for the injector pump, but the camshaft sprocket should be 45-50nm, so I would suggest using that figure - along with some threadlock/torqueseal. Les. Quote Link to comment Share on other sites More sharing options...
