Tonk Posted February 15, 2006 Share Posted February 15, 2006 which is the best way to strip chrome off of summat? shotblasting? or can it be painted onto without stripping? Quote Link to comment Share on other sites More sharing options...
MogLite Posted February 15, 2006 Share Posted February 15, 2006 which is the best way to strip chrome off of summat? shotblasting? or can it be painted onto without stripping? Chromers can take it off electrically I believe Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 15, 2006 Share Posted February 15, 2006 Grit blasting will remove it, or you could key it with wet/dry paper for painting. Maybe etch prime would do that same job. Les. Quote Link to comment Share on other sites More sharing options...
02GF74 Posted February 15, 2006 Share Posted February 15, 2006 seem to recall when I got some bits chrome plated the peeps said they had to dip in acid (or other stuff) to remove the old chrome so my money would be on chemical. ofcourse mechanical removal (wetndry/sand paper) would do it too - a dremel with a sanding wheel would be quite effective. - should have said electo-chemical so ^^^^^ is right about electric. Quote Link to comment Share on other sites More sharing options...
rtbarton Posted February 15, 2006 Share Posted February 15, 2006 Grit blasting will remove it, or you could key it with wet/dry paper for painting. Maybe etch prime would do that same job.Les. Gritblasting can be hard work shifting chrome - it will remove it easily where it has bubbled, but you end up with a ragged edge where the chrome is still sticking. Grit blasting will roughen it up OK, but you may need a special primer if you want to paint it. Quote Link to comment Share on other sites More sharing options...
Tonk Posted February 15, 2006 Author Share Posted February 15, 2006 i'll go with grit balsting then powder coating, it can only fall off Quote Link to comment Share on other sites More sharing options...
minivin Posted February 15, 2006 Share Posted February 15, 2006 i'll go with grit balsting then powder coating, it can only fall off if you get a sanding disc on an angle grinder and "hard-key" it before the sand blasting, it should all come off then, anything left you should be able to remove with the sanding grinder before powder coat and all will be funky dudey Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted February 15, 2006 Share Posted February 15, 2006 Chromers can take it off electrically I believe That is the route I have taken in the past. Quote Link to comment Share on other sites More sharing options...
minivin Posted February 15, 2006 Share Posted February 15, 2006 one of the problems they got with anodic remove is the platers hate doing it due to the risk of any impurities (weld flux, grease, dirt et cetera) getting into their bath and making a mess, have had a couple platers refuse to do any work until the items I had were spotless Quote Link to comment Share on other sites More sharing options...
Niall_CSK Posted February 16, 2006 Share Posted February 16, 2006 i'll go with grit balsting then powder coating, it can only fall off I have tried blasting it. If you have rust bubbles you end up with an uneven surface, if you keep blasting the steel being softer disappears even faster (corroded areas are even softer than the original steel) and you end up with very big pits which have to be filled either with epoxy or built up by welding & grinding to get a decent finish back. If you are going to paint it and it's not too complex a surface I would go over it with medium to fine sander, fill up the pits then prime with a good etch primer. If you want to powder coat it the chrome has to come off entirely, my usual PC guy said he would do it if I insisted but would have to charge me extra for the additional blasting and would not guarantee the longevity of the results for more than a week. Not trying to put you off, just passing on my own experiences, never dealt with electro chemical stripping of chrome. Quote Link to comment Share on other sites More sharing options...
rtbarton Posted February 16, 2006 Share Posted February 16, 2006 As it happens a chromed scooter wheel came in for blasting yesterday. It was a very thin coat, not even on nickel and it just flew off, but I've had some in where it would just not shift. Niall's remarks about pitting are so true! some stuff I've turned out looks more like a lunar landscape once all the rust has gone. Quote Link to comment Share on other sites More sharing options...
Tonk Posted February 16, 2006 Author Share Posted February 16, 2006 hmmmmm, well its in for blasting, i'll just havta wait and see wot it looks like when it comes back Quote Link to comment Share on other sites More sharing options...
