macandrc Posted March 4, 2009 Share Posted March 4, 2009 afternoon all, i snapped the top off the bleed nipple on the power steering box when changing my engine! as such i cant bleed my power steering, does anyone know where i can buy a replacement? and what size? its a 1986 TD power steering box colin Quote Link to comment Share on other sites More sharing options...
western Posted March 4, 2009 Share Posted March 4, 2009 for a 4 bolt box you need 1 x RTC4395 Quote Link to comment Share on other sites More sharing options...
macandrc Posted March 5, 2009 Author Share Posted March 5, 2009 for a 4 bolt box you need 1 x RTC4395 Spot on thanks, just got to work out how to get the broken part out Quote Link to comment Share on other sites More sharing options...
smo Posted March 5, 2009 Share Posted March 5, 2009 A stud extractor is your best bet, as its hollow you dont even need to drill the old nipple, just screw the extractor in and itll come out Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted March 5, 2009 Share Posted March 5, 2009 When I used to work for Bodge & Scarper we found that as long as there was some fluid still in there, then jacking the front wheels off the ground and turning it quickly lock to lock a few times with the engine running would generally bring the air out... I have never tried it on a Land Rover, but it might be worth a shot.. Quote Link to comment Share on other sites More sharing options...
neiltd590 Posted March 6, 2009 Share Posted March 6, 2009 i checked my 4 stud pas box- adwest - bleed nipple is a 10mm standard metric one, i bought some recently for my brake calipers i checked and they fit - they were about 90p each from a local factors. Quote Link to comment Share on other sites More sharing options...
macandrc Posted March 8, 2009 Author Share Posted March 8, 2009 i checked my 4 stud pas box- adwest - bleed nipple is a 10mm standard metric one, i bought some recently for my brake calipers i checked and they fit - they were about 90p each from a local factors. tried the extractor and it bloody snapped in the hole! can i unbolt the top panel of the steering box to remove it that way? any seals i need to buy? colin Quote Link to comment Share on other sites More sharing options...
western Posted March 8, 2009 Share Posted March 8, 2009 this should help Quote Link to comment Share on other sites More sharing options...
