bobrick Posted March 7, 2009 Share Posted March 7, 2009 hi all its been a while but i have a question does anybody know what size the brake pipes and unions etc are used on a defender 90. at the moment i am overhauling a discovery rear axle to fit to my 90 and want to make sure i have the right spec pipe. cheers in advance will Quote Link to comment Share on other sites More sharing options...
smo Posted March 8, 2009 Share Posted March 8, 2009 3/16 pipes with 10mm unions on mine, it might vary with age tho. Quote Link to comment Share on other sites More sharing options...
howard14 Posted March 8, 2009 Share Posted March 8, 2009 hi allits been a while but i have a question does anybody know what size the brake pipes and unions etc are used on a defender 90. at the moment i am overhauling a discovery rear axle to fit to my 90 and want to make sure i have the right spec pipe. cheers in advance will Hi will. Have just seen your project pics. That chassis is pretty bad, you know. I have been spending the last few months plating up an R reg 90 that is better in parts, but worse in others than yours. I have good facilties, and I like to work to a good standard so my 'Project' chassis will be just fine... At what cost though? That is time, welding consumibiles, hours and hours of mig-weld grinding, then do it all again, and when it's done it's still a repaired chassis. So, 'bite the bullet' and plan for a new chassis . I wish I had, it's why they make them.... Lots of luck. Howard. 2x300TdiDef. Ps By the way, my brake pipes measure more than 3/16" but less than 5mm. So I dont know what size Kunnifer to order!! Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 8, 2009 Share Posted March 8, 2009 3/16" pipe throughout, but early models might have 3/8" fittings and later will be 10mm fine thread. Just to confuse things - 3/8" will screw into 10mm, but not bite. 10mm won't screw into 3/8" (it's slightly smaller dia). Les. Quote Link to comment Share on other sites More sharing options...
howard14 Posted March 9, 2009 Share Posted March 9, 2009 3/16" pipe throughout, but early models might have 3/8" fittings and later will be 10mm fine thread. Just to confuse things - 3/8" will screw into 10mm, but not bite. 10mm won't screw into 3/8" (it's slightly smaller dia).Les. Many thanks from me Les. Very best regards. Howard. 2x300TdiDef. Quote Link to comment Share on other sites More sharing options...
bobrick Posted March 11, 2009 Author Share Posted March 11, 2009 cheers for all you help every one looks like ill be sourcing some 3/16" pipe Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 11, 2009 Share Posted March 11, 2009 Most motor factors sell cupro-nickel or copper brake pipe in reels of 30-feet or so for about £10. One pack is enough to do an entire vehicle. Les. Quote Link to comment Share on other sites More sharing options...
Ibex94 Posted March 12, 2009 Share Posted March 12, 2009 I bought a tub of of the 10mm male nuts, let me know how many you want and I'll see what I've got left. Rob Quote Link to comment Share on other sites More sharing options...
max-ie Posted March 12, 2009 Share Posted March 12, 2009 Dont pee about fixing an old chassis. I spent six months fixing mine before i gave up. Then made a range rover chassis fit and paying the cost now with DVLA and SVA. Pain in the a*&se. Get a good replacement, rebuild and enjoy Quote Link to comment Share on other sites More sharing options...
howard14 Posted March 13, 2009 Share Posted March 13, 2009 Dont pee about fixing an old chassis. I spent six months fixing mine before i gave up. Then made a range rover chassis fit and paying the cost now with DVLA and SVA. Pain in the a*&se. Get a good replacement, rebuild and enjoy So there yer go... Howard. Quote Link to comment Share on other sites More sharing options...
defender300td1 Posted March 13, 2009 Share Posted March 13, 2009 try to get the nickel plated pipe last longer than copper but harder to bend Quote Link to comment Share on other sites More sharing options...
