ball joint thread help
fabsj
hi all
i went to fit a new ball joint to mates 90 and the thread in the
track rod has some s**t in it
i think by the look of it the thread is 11/16 unf left hand
can any one confirm this as i need to clean the thread out so it does not
damage another ball joint
thanks in advance
frank
__________________________________
If all you want to do is clean the thread then take the old TRE and cut down the middle of the thread with a hacksaw. Then with an angle grinder grind back the trailing edge of the thread so that you have turned your TRE into a tap.
This works fine as long as you don't come back and say the TRE is FUBAR with hardly any discernible thread.
The tap you need to buy will be lots of pounds in which case it may still be cheaper to make a brand new TRE into a tap and pop it in your toolbox for next time.
Steve
I have the correct taps LH and RH if you want to borrow them.
Not far from you, Shrek knows where I am.
If there is much damage though a new bar would be a good idea just to be safe due to the serious consiquences if it fails.
