Fern Posted March 19, 2009 Share Posted March 19, 2009 I'm going to replace my o2 sensors. The original ones are very expensive. Here i fould the replacement from Nissan and other. http://www.rangerovers.net/rrpartsv.htm#osensor But also I found some reviews that Bosch 13021 did not work. Does anybody has experience in replacing stock o2 sensors with Nissan's or bosch's? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 19, 2009 Share Posted March 19, 2009 Hmmmm, I thought RR sensors were Titania and hence resistive and most other sensors, including "universal" ones, were the common Zirconia ones that generate a voltage. I'm not sure what the ECU would do if you replace one type with the other but I can't see how it would work properly Quote Link to comment Share on other sites More sharing options...
Dave W Posted March 19, 2009 Share Posted March 19, 2009 Although LR use Titania they use the type that have an internal voltage source, tapped off the heater supply, which supplies an output voltage between 0v and 1v. (some titania sensors output between 0v and 5v). To the ECU a zirconia sensor would look similar to the standard LR titania sensor. Quote Link to comment Share on other sites More sharing options...
Dave W Posted March 19, 2009 Share Posted March 19, 2009 If you take a look at http://www.lambdasensor.com/main/lrover.htm They do a choice of direct fit lambdas (come with the right connector etc) or universal, which are cheaper. A universal titania 12mm (so you don't have to fit a new boss to the exhaust) will cost you just over 60 quid. I buy all my lambda sensors from the above site. As can be seen from their list, not all LR lambdas are titania, some are zirconia so choose your model carefully. A direct fit version normally costs about £10 more than a universal. Quote Link to comment Share on other sites More sharing options...
teabag Posted March 19, 2009 Share Posted March 19, 2009 An interesting site on the dark subject of lambda sensors, also interesting is the note "Test and/or replace every 30,000 miles". who does that. Quote Link to comment Share on other sites More sharing options...
Fern Posted March 19, 2009 Author Share Posted March 19, 2009 Zirconia will not work. A friend of mine already has an experience. Titania - yes. I'm looking for them. They are produced by the NTK ceramics company and I just want to know did anybody fit Nissan's Sentra oxygen sesor and had success? 'Cause I found different results, somebody say thay work and others are saying they still had and error. Quote Link to comment Share on other sites More sharing options...
