bernie Posted March 31, 2009 Share Posted March 31, 2009 I have a 1994 300 tdi with a standard original radio fitted, how do i remove it, cant see any holes at side, but it is fixed fast. Quote Link to comment Share on other sites More sharing options...
landmannnn Posted March 31, 2009 Share Posted March 31, 2009 I have a 1994 300 tdi with a standard original radio fitted, how do i remove it, cant see any holes at side, but it is fixed fast. Not sure, but if you want I will ask the lads outside my local londis, I am sure they will know. Quote Link to comment Share on other sites More sharing options...
MarkL Posted April 1, 2009 Share Posted April 1, 2009 Hi Bernie, I have a 2003 TD5 110 and I replaced the crappy LR radio with a nice Kenwwod one! There should be a small hole on either side of the unit, about 1cm in from the edge .. there's allen head screws in them .. get a 2.5mm allen key (think it was 2.5) and loosen them .. a wiggle and a pull and hopefully it should come out! Hopefully that will work on your '94 radio! There's a security code for the radio which you will need if you're going to re-fit it .. a main LR dealer will be able to help you with this if you don't have it. Didn't bother me as I had no plans for using it again! Mark Quote Link to comment Share on other sites More sharing options...
dirkthe1 Posted April 1, 2009 Share Posted April 1, 2009 Not sure, but if you want I will ask the lads outside my local londis, I am sure they will know. if you ask nicely, they'd probably do it for a small fee-the contents of your ashtray.... Quote Link to comment Share on other sites More sharing options...
RILEY Posted April 1, 2009 Share Posted April 1, 2009 LUMP HAMMER no seriously is it a dash mount ? just undo the mount screws and take it out Quote Link to comment Share on other sites More sharing options...
BogMonster Posted April 1, 2009 Share Posted April 1, 2009 Hi Bernie,I have a 2003 TD5 110 and I replaced the crappy LR radio with a nice Kenwwod one! There should be a small hole on either side of the unit, about 1cm in from the edge .. there's allen head screws in them .. get a 2.5mm allen key (think it was 2.5) and loosen them .. a wiggle and a pull and hopefully it should come out! Hopefully that will work on your '94 radio! There's a security code for the radio which you will need if you're going to re-fit it .. a main LR dealer will be able to help you with this if you don't have it. Didn't bother me as I had no plans for using it again! Mark Older ones don't use this system - all the ones I have seen use keys of one sort or another but on some models you have to pull off the plastic surround to the radio to see the key holes - it just unclips if it is one of those types. Quote Link to comment Share on other sites More sharing options...
