crazyfarmerboy Posted May 12, 2009 Share Posted May 12, 2009 How do i replace the side indicators on my 110, is this me being stupid but how do i get to the back of them to take the old one's off? Quote Link to comment Share on other sites More sharing options...
Aragorn Posted May 12, 2009 Share Posted May 12, 2009 they just pull out afaik Quote Link to comment Share on other sites More sharing options...
SteveG Posted May 12, 2009 Share Posted May 12, 2009 just twist anti-clockwise and pull Quote Link to comment Share on other sites More sharing options...
crazyfarmerboy Posted May 12, 2009 Author Share Posted May 12, 2009 This may mean bad times because mine are held on with bolts through to the other side side and they have rusted away, i have the same replacement and they have bolts coming out of the back also, is there a way to get between the two wings without removing? Quote Link to comment Share on other sites More sharing options...
max-ie Posted May 12, 2009 Share Posted May 12, 2009 Does it have wheel arch spats on it. If so then pull the retaining plastic grometts out from under the arch and then peel back the inner edge to reveal the back of the indicator. New grometts are available on the internet if you break any. Max Quote Link to comment Share on other sites More sharing options...
disco tony Posted May 12, 2009 Share Posted May 12, 2009 cant remember for sure but I think I took the headlamp assy. out and stretched in there. sorry, dont think thats right now, I'll keep thinking..... was it through the wing top grill? Quote Link to comment Share on other sites More sharing options...
crazyfarmerboy Posted May 16, 2009 Author Share Posted May 16, 2009 ok, you have to peel back the arches, i want to take them off, so how di i do this. there is a line of plactic studs, i have tried pulling them but it did not work, is there a technique to it? cheers Quote Link to comment Share on other sites More sharing options...
errol209 Posted May 16, 2009 Share Posted May 16, 2009 ok, you have to peel back the arches, i want to take them off, so how di i do this. there is a line of plactic studs, i have tried pulling them but it did not work, is there a technique to it? cheers You need to push the central pin in on each one (they are about 2mm diameter) first using a nail and hammer. Odds on you'll lose 90% of the pins, so you'll need new "studs" to put the arches back on. BTW, did you get the nuts with your indicators? Quote Link to comment Share on other sites More sharing options...
cieranc Posted May 16, 2009 Share Posted May 16, 2009 Yes, in the centre of each clip is a straight round plastic rod. Get something the same diameter and push the plastic rod into the clip, right in until it comes out the other side. Now the clip should pull out. Quote Link to comment Share on other sites More sharing options...
antony110 Posted May 17, 2009 Share Posted May 17, 2009 Yes, in the centre of each clip is a straight round plastic rod. Get something the same diameter and push the plastic rod into the clip, right in until it comes out the other side. Now the clip should pull out. Hi i have removed mine recently (the wheel arches)i used a trim removal tool brought of ebay for a few pounds, was very useful and made the job very easy regards antony110 Quote Link to comment Share on other sites More sharing options...
