hoss1720 Posted May 30, 2009 Share Posted May 30, 2009 Been out this morning and on my return journey the ABS AND TRACTION CONTROL warnining lights came on and stayed on. My vehicle is a Disco 2 4.0 V8 1999. Any suggestions for a quick fix or does this need to be hooked up for a diagnosis? cheers Quote Link to comment Share on other sites More sharing options...
LittleBlue88 Posted May 30, 2009 Share Posted May 30, 2009 Sounds like one of the abs sensors has kicked the bucket,but to find out which one you will need to get it plugged into a diagnostics computer Quote Link to comment Share on other sites More sharing options...
steve_a Posted May 31, 2009 Share Posted May 31, 2009 I've seen comments that a nanocom will tell you the SLAB codes, even though it won't talk to the ECU on the V8. I'd be interested to know if it does since I expect I could find one of those locally to see what mine is whinging about. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 1, 2009 Share Posted June 1, 2009 What bluey said ^^^ do a search on here it has been covered loads of times but yes most likely an ABS sensor Quote Link to comment Share on other sites More sharing options...
hoss1720 Posted June 1, 2009 Author Share Posted June 1, 2009 once the fault has been diagnosed and the sensor has been replace will the lights go out automatically or will they need resetting. the reason I ask is that once diagnosed I intend to replace the sensor myself.But if it needs to be reset I might aswell let the garage change it. any suggestions? Quote Link to comment Share on other sites More sharing options...
cipx2 Posted June 2, 2009 Share Posted June 2, 2009 I strongly suggest what's been suggested already, do a search in this section. The light will go out after you fix the problem (although the error code will remain stored but this won't bother you at all). Having a LR garage replace the ABS sensor means they will replace the entire hub. You could have find both answers in this thread: http://forums.lr4x4.com/index.php?showtopic=7982 To search the forum I recommend you to read this thread first: http://forums.lr4x4.com/index.php?showtopic=35133 Quote Link to comment Share on other sites More sharing options...
