SpenB Posted June 5, 2009 Share Posted June 5, 2009 Sorry its probably been doon so much...but... I've just had the bulkhead out rigger replaced on the drivers side but it must be at a slightly different height as the doors moved now. Altered the strike plate so door shuts, but the door seems to be about 1/4" too low. The door seems to be pretty square in the apperture. Its as if I need to lift the whole door up 1/4". So I need an impact drive to undo the hinge screws? Then just hit away? I take it these will either brake off (need to dirll out) or the j clip will give way. Is there any tips or ideas out there before I start it Saturday? Sorry for the stupid questions but if you dont know, you just dont know. Done a search and items are close but just wanted some more info to give me some confinence. Cheers, SpenB Quote Link to comment Share on other sites More sharing options...
darkman Posted June 5, 2009 Share Posted June 5, 2009 Spray all the nuts with WD40, slackoff the bolts n try n lift the door. With a hammer if you like, but use a wood block. good luck! Quote Link to comment Share on other sites More sharing options...
SpenB Posted June 5, 2009 Author Share Posted June 5, 2009 Thanks. I'll try it in the morning. Quote Link to comment Share on other sites More sharing options...
Orange Posted June 5, 2009 Share Posted June 5, 2009 I started WD-40-ing my door hinge bolts about 2 weeks ago in anticipation of changing the doors. The bulkhead ones are now free, but the door ones aren't, but that's not too much of an issue. I would recommend replacing the bolts with stainless ones. Available on ebay as complete kits, or from your local fastner shop... Quote Link to comment Share on other sites More sharing options...
Jimmy Two-Jacks Posted June 5, 2009 Share Posted June 5, 2009 Hi Spen, I got the same identical problem just done outriggers and the passenger door has dropped, striker plate wont alter possition enough to alow door to shut. Cant get the bolts out of the hinge so I have decided to lift the door gently with a farmjack with wooden softening block underbeath the door to see if that either loosens the bolts or even just fixes the problem,if that dont work I will probably drill the bolts out and try to re-fit the door from scratch I will let you know how I get on. If you solve the problem before me let me know what method worked. Cheers James Quote Link to comment Share on other sites More sharing options...
markyboy Posted June 5, 2009 Share Posted June 5, 2009 I found that slackening the bulkhead outrigger bolt and jacking under the bulkhead before retightening the bolt brought my door back into line. Worth a try IMHO. HTH Mark Quote Link to comment Share on other sites More sharing options...
SpenB Posted June 6, 2009 Author Share Posted June 6, 2009 Thanks for the replies. In work today for a 12hr stint and Sunday for 8hrs but ill try and have a look Sunday night. SpenB Quote Link to comment Share on other sites More sharing options...
