mattltm Posted June 6, 2009 Share Posted June 6, 2009 Hi all I have a problem with 2nd gear in my td5 defender (manual). It's been like it since I purchased it (that will teach me to trust an ebay seller and not test drive!) and now I want to get it sorted out. When I change to 2nd the gear grinds. It will go in if I give it a push or if in slow down to around 7mph. All other gears are fine and nice and smooth. Any ideas on what I should look at first? Quote Link to comment Share on other sites More sharing options...
Gromit Posted June 6, 2009 Share Posted June 6, 2009 I would say there's not much you can do other than change the oil and see what comes out. Sounds like 2nd gear synchro is worn. Does double clutching help? Could be a dragging clutch, but that'd affect all gears. Quote Link to comment Share on other sites More sharing options...
western Posted June 6, 2009 Share Posted June 6, 2009 as my learned friend above says, change the oil & don't try to rush the change through. Quote Link to comment Share on other sites More sharing options...
Gromit Posted June 6, 2009 Share Posted June 6, 2009 out of curiosity, what gearbox does the TD5 get? R380? Quote Link to comment Share on other sites More sharing options...
jbs Posted June 6, 2009 Share Posted June 6, 2009 Try changing your gearbox oil to mt75 as it made a hell of a difference to my LT77-about £4.00 a litre from auto parts places Quote Link to comment Share on other sites More sharing options...
reb78 Posted June 6, 2009 Share Posted June 6, 2009 out of curiosity, what gearbox does the TD5 get? R380? Yep, Its the R380 I agree. Change the oil first and don;t rush the change - positive pressure on the gearstick without forcing it and let it fall into gear under that pressure. Quote Link to comment Share on other sites More sharing options...
western Posted June 6, 2009 Share Posted June 6, 2009 out of curiosity, what gearbox does the TD5 get? R380? Yes filled with MTF94 fluid instead of ATF Quote Link to comment Share on other sites More sharing options...
mattltm Posted June 7, 2009 Author Share Posted June 7, 2009 Thanks for the replies. What oil should I put in? MT75 or MTF94? Quote Link to comment Share on other sites More sharing options...
reb78 Posted June 7, 2009 Share Posted June 7, 2009 Thanks for the replies. What oil should I put in? MT75 or MTF94? MTF94 is what land rover recommend Quote Link to comment Share on other sites More sharing options...
western Posted June 7, 2009 Share Posted June 7, 2009 MTF94 is the factory filled fluid, provided the MT75 meets or exceeds the same specifications you can use that instead. Quote Link to comment Share on other sites More sharing options...
mattltm Posted June 7, 2009 Author Share Posted June 7, 2009 so MTF94 is the "proper" one but MT75 may be better? Wow oil is complicated! I know nothing about it so I guess MTF94 is the one for me. Quote Link to comment Share on other sites More sharing options...
reb78 Posted June 7, 2009 Share Posted June 7, 2009 so MTF94 is the "proper" one but MT75 may be better? Wow oil is complicated! I know nothing about it so I guess MTF94 is the one for me. No idea about MT75. I'd just stick with what was intended for now. Quote Link to comment Share on other sites More sharing options...
mattltm Posted June 7, 2009 Author Share Posted June 7, 2009 Great. I will get some MTF94 and see how it goes. I have been out and tried double clutching into second but it makes no difference so I guess it will be the synchro that's knackered. Looking at the worst, if it is the gear, does that mean a new box or just a new second gear? And is it a easy job of do I need to start saving for a real mechanic? Thanks all. Quote Link to comment Share on other sites More sharing options...
western Posted June 7, 2009 Share Posted June 7, 2009 probably a dying synchro unit, but drop Ashcrifts a phone call or e.mail, for advice, not sure if it's easy to change. Quote Link to comment Share on other sites More sharing options...
Gromit Posted June 7, 2009 Share Posted June 7, 2009 Looking at the worst, if it is the gear, does that mean a new box or just a new second gear? And is it a easy job of do I need to start saving for a real mechanic? If you were pulling the box apart to replace a synchro, it'd only make sense to overhaul to box completely. Have a look at this thread for a recent conversation on the topic. Quote Link to comment Share on other sites More sharing options...
