nickjaxe Posted June 7, 2009 Share Posted June 7, 2009 As it says in the title guys, I have got an L reg disco for its 200tdi engine and I am stuck, I just cannot get the very top bell housing nut off there is just no room between the bell housing and the body, can anybody put me out of my misery it seems impossible, I seem to have 13 when I thought there were supposed to be 12. Nick. Quote Link to comment Share on other sites More sharing options...
western Posted June 7, 2009 Share Posted June 7, 2009 take the engine mounts rubber parts off & lower the engine down with a engine crane. Quote Link to comment Share on other sites More sharing options...
K88 MUD Posted June 7, 2009 Share Posted June 7, 2009 Drop the gearbox X member and you can use several extension's and a socket to reach over the top of the box. Quote Link to comment Share on other sites More sharing options...
vavu Posted June 7, 2009 Share Posted June 7, 2009 Can be really frustrating but realistically as K88 MUD said taking out the cross member and letting the gearbox and engine tilt downwards will give you some clearance you can just about access it with a socket extension through the inside of the vehicle. Would be sensible to either put some of the other bolts back in while you undo this one or make sure the gearbox is very well supported. I'm in the process of Changing the Clutch and rear oil seal on my 300tdi so had to do all this on Saturday. When I put it all back together I'm going to use an engine hoist through the side door as I really don't fancy taking all that weight while trying to line it up. I changed the gearbox on my SIII that way and it made life very easy!! Hope you get it sorted!! Quote Link to comment Share on other sites More sharing options...
Les Henson Posted June 8, 2009 Share Posted June 8, 2009 If you remove the gearbox rubbers and mounts, the gearbox will rest down at the back, then extension bars to get at the nut - you'll need to hug the bellhousing to guide the socket onto the nut between the strengthening ribs. If the rest of the vehicle is scrap, then cut a hole in the bulkhead and undo the nut through the transmission tunnel. Les. Quote Link to comment Share on other sites More sharing options...
nickjaxe Posted June 8, 2009 Author Share Posted June 8, 2009 It is going to be scraped Les so I will try you idea, thanks everybody. Nick. Quote Link to comment Share on other sites More sharing options...
joe sharpe Posted June 9, 2009 Share Posted June 9, 2009 take les's advice i did and changed clutch etc by myself well chuffed cheers joe Quote Link to comment Share on other sites More sharing options...
V8CAMEL Posted June 9, 2009 Share Posted June 9, 2009 take les's advice i did and changed clutch etc by myself well chuffed cheers joe and if you werent scrapping the vehicle dont bother putting it back in Quote Link to comment Share on other sites More sharing options...
