draper40 Posted June 20, 2009 Share Posted June 20, 2009 What is the name of the piece of metal bracketry that bolts onto the front of the PAS box at one end and the panhard rod end at the other? Thanks Pete Quote Link to comment Share on other sites More sharing options...
J@mes Posted June 20, 2009 Share Posted June 20, 2009 the drop arm? Quote Link to comment Share on other sites More sharing options...
Gromit Posted June 20, 2009 Share Posted June 20, 2009 What is the name of the piece of metal bracketry that bolts onto the front of the PAS box at one end and the panhard rod end at the other? Tie bar to panhard rod. Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted June 20, 2009 Share Posted June 20, 2009 Do you mean one of these? I'm not sure what it's called though! sorry. Steve Quote Link to comment Share on other sites More sharing options...
Megansfolly Posted June 20, 2009 Share Posted June 20, 2009 Do you mean one of these? I'm not sure what it's called though! sorry. Steve i have one of these for sale if thats it Quote Link to comment Share on other sites More sharing options...
Gromit Posted June 20, 2009 Share Posted June 20, 2009 Do you mean one of these? I'm not sure what it's called though! sorry. That is just called a Mounting Arm . The Tie Rod goes from that to the PAS box. Quote Link to comment Share on other sites More sharing options...
The Badger Posted June 21, 2009 Share Posted June 21, 2009 I had this same problem, it is just a mounting arm. If you are looking at that and want to make a change that makes life easier in the future, replace the drop arm to a disco one. This means that instead of having a ball joint in the arm, it is connected with a screw in ball joint that is easily replaceable. With this mod, you also need a new drag link arm, one with screw in ball joints at either end. If you still want a steering damper, then you can get a bracket that is attached to the new drag link rod. just an idea. Quote Link to comment Share on other sites More sharing options...
draper40 Posted June 22, 2009 Author Share Posted June 22, 2009 I managed to get one from an excellent indepednant land rover garage for £0 but I did buy i speedo cable at the same time! Pete Quote Link to comment Share on other sites More sharing options...
