Bowie69 Posted June 30, 2009 Share Posted June 30, 2009 I've got the rear floor out the Rangie at the moment, and a nice shiny Ali one from QTDarren ready to go in, and was wondering if there was anything else I should tackle whilst I have moderately better access to the fuel tank/chassis etc before I pop rivet the whole thing down? Top of the fuel pump and the steel fuel lines look a bit crusty, so will probably replace the lines, is it worth chucking a new fuel pump in it now? It's done 110K miles ish, so done a fair old distance... Any brake lines will get inspected and changed if necessary, chassis scrubbed, painted and waxoyled. Anything else? Many thanks Quote Link to comment Share on other sites More sharing options...
q-rover Posted June 30, 2009 Share Posted June 30, 2009 Sounds about right. Quote Link to comment Share on other sites More sharing options...
Mark Posted June 30, 2009 Share Posted June 30, 2009 Rear Body Crossmember? Access is far better with no floor in. Mark Quote Link to comment Share on other sites More sharing options...
ChrisV8 Posted June 30, 2009 Share Posted June 30, 2009 Would agree with that give the rear x member a real good look at and possibly take the tank out and look very carefully at the rear chassis legs. Having had to spend a few hours welding daughters RR which appeared to have been used for launching boats given all the rot was at the back it would make sense to spend some time whilst the floor is out. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 30, 2009 Author Share Posted June 30, 2009 Thanks guys! Rear Body Crossmember? Access is far better with no floor in.Mark Thanks Mark, forgot to mention, already got that sorted, new one went in about a week ago, not sure I would have got it in without taking the floor out TBH Any thoughts on the fuel pump, is it worth switching for a new one at this mileage? Thanks again Quote Link to comment Share on other sites More sharing options...
q-rover Posted June 30, 2009 Share Posted June 30, 2009 Whilst your there would be rude not to. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted June 30, 2009 Share Posted June 30, 2009 Drop the tank and treat the chassis rails. RR's of that vintage have rubbish steel in the chassis and the rear portion is particularly susceptible. It will give you the chance to sort out a rear winch mount without blowing yourself up too... Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 30, 2009 Author Share Posted June 30, 2009 Drop the tank and treat the chassis rails. RR's of that vintage have rubbish steel in the chassis and the rear portion is particularly susceptible.It will give you the chance to sort out a rear winch mount without blowing yourself up too... The rails look pretty good TBH, from what I can see.... but I hate to think what the tank is hiding... will drop it out and take a look, thanks As far as a rear winch mount, that's another project for another month, got enough on my plate as it is Will stick a new pump in it as well, just to make sure... Quote Link to comment Share on other sites More sharing options...
sheltie50 Posted June 30, 2009 Share Posted June 30, 2009 Have a good look at the chassis xmember while your in there, it's all so much easier with the floor out, it's a good chance to do anything and everything. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted July 1, 2009 Share Posted July 1, 2009 Oh, another thing, Remove the boge self leveller if it is still on - the top bolts are nice and easy to get to with the floor out. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 1, 2009 Author Share Posted July 1, 2009 Ah, that's a job for today when I have a few minutes where my computer stops receiving new emails -off to soak it all with penetrating oil Chassis cross member is pretty rot free, surprisingly Quote Link to comment Share on other sites More sharing options...
Rustyrangie Posted July 1, 2009 Share Posted July 1, 2009 Found this when I did mine a couple of years ago. While you're checking fuel lines, brake lines etc. have a good prod around the supports at the end of the round chassis crossmember where the fuel & brake lines are clipped. The same spot on the opposite end too.. Lovely rust traps there. If you need to weld them it's much easier if you cut a flap in the floor slope and bend it out of the way. Bob Quote Link to comment Share on other sites More sharing options...
